#2027: Upgrade GIT on TracSVN machine
Reporter: strk | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
Gitea requires GIT version 1.8.2 or later, so in order to upgrade from
Gogs to Gitea we need a newer version of GIT installed.
Last time I tried this it left some dirty packages around, now ticketting
it to handle it in a better way (compile on the machine ?)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2027>
OSGeo <http://www.osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by strk):
NOTE: this is needed for Gitea upgrade (#2028)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2027#comment:1>
Keywords: |
Comment (by martin):
I tried to rebuild the corresponding GIT packages from Debian7 on Debian6
(which is on TracSVN), but after the n-th element in the dependency chain
I hit a circular dependency between two different Python module packages
(python-testtools requires python-fixtures and vice-versa). That's where I
stopped.
Therefore I'd suggest to try out if it's possible to lower the
requirements.
I might try to install packages directly from Debian7 (requires upgrading
the libc6 ecosystem beforehand), but that won't happen this weekend.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2027#comment:2>
Type: task | Status: closed
Component: Systems Admin | Resolution: wontfix
Keywords: |
Changes (by strk):
* status: new => closed
* resolution: => wontfix
Comment:
I've uploaded a version of gitea that accepts GIT 1.7.0
See https://github.com/go-gitea/git/pull/90
The /etc/init.d/gitea currently links there.
I'm closing this as wontfix
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2027#comment:3>
Type: task | Status: reopened
Keywords: |
Changes (by strk):
* status: closed => reopened
* resolution: wontfix =>
Comment:
Reopened as it looks like a couple of functions still need newer git:
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2027#comment:4>
Keywords: |
Changes (by strk):
* status: reopened => closed
Comment:
We don't need this anymore as Gitea-1.3+ supports git back to 1.7.2
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2027#comment:5>
