#2077: Test with PHP7
Reporter: cvvergara | Owner: webcom@…
Type: task | Status: assigned
Priority: normal | Milestone: Unplanned
Component: WebSite | Keywords: Test
Set up of website with PHP7 is here
https://staging2.www.osgeo.org
Tests:
- Login using ldap
- Login using OpenID
- Navigate the site
- Navigate the administration site
- Verify that the gravatar are OK
- Add pages
- Remove pages
- Add Person images
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2077>
OSGeo <http://www.osgeo.org/>
Component: WebSite | Resolution:
Keywords: Test |
Comment (by cvvergara):
Done:
- Login using ldap
- Navigate the site
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2077#comment:1>
Keywords: Test |
Comment (by strk):
OpenID Login fails with both "staging" (PHP6) and "staging2" (PHP7),
although in different ways (PHP7 is unable to discover identity
server, PHP6 ends up giving me a Forbidden message)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2077#comment:2>
Keywords: Test |
Tests Done:
- added a post
- added a feature image (never saw it in the preview or the published
page)
- Used the SEO tool
- Moved to trash a post (the one added)
- Deactivated the OpenID plug in
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2077#comment:3>
Keywords: Test |
Tests Done:
- Added an image to user profile
- Used the form in https://staging2.www.osgeo.org/about/contact/
- Who gets the mails?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2077#comment:4>
Keywords: Test |
- tested changing a form
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2077#comment:5>
Keywords: Test |
- Tested changing time zone
- forms email test: fields are saved
- TODO, test that email is received
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2077#comment:6>
Keywords: Test |
Comment (by robe):
found something that doesn't work. The system snapshot plugin I had
installed on staging.osgeo.org that worked there, just shows a blank
screen on staging2. I tried to uninstall and reinstall, but that didn't
help.
Issue is documented here https://wordpress.org/support/topic/fatal-error-
when-running-on-php7/ . It's a very old plugin and doesn't give me any
info I can't easily get from shell so not super critical.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2077#comment:7>
Keywords: Test |
Comment (by robe):
cvvergara I installed sendmail on staging2 and was able to get a test
message I sent via the WP Mail Plugin.
I did the same on the staging.www.osgeo.org since that was missing
sendmail as well. Let me know if you run into issues with test mail send.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2077#comment:8>
Type: task | Status: closed
Component: WebSite | Resolution: fixed
Keywords: Test |
Changes (by robe):
* status: assigned => closed
* resolution: => fixed
Comment:
I think we are done with this have https://staging.www.osgeo.org now on
web18a with PHP 7
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2077#comment:9>
