#2092: Install Weblate in Docker
Reporter: robe | Owner: robe
Type: task | Status: closed
Priority: normal | Milestone: Sysadmin Contract 2021-II
Component: Systems Admin | Resolution: fixed
Keywords: |
Comment (by robe):
I did preliminary tests with postgis and fumbled my way thru getting it to
pull all files (auto create for each using component discovery add on)
https://docs.weblate.org/en/latest/admin/addons.html#component-discovery .
It wasn't intuitively obvious. I also set up a gitea webhook
https://docs.weblate.org/en/latest/api.html?highlight=gitea#post--hooks-
gitea- to push new changes on commit to repo. There are similar hooks for
github, gitlab, and bitbucket available.
You can see here:
https://weblate.osgeo.org/projects/postgis/
Things on my list to try:
1) Getting weblate to send pull requests
2) I setup a blank project for postigs-workshop (hosted on github) - that
is a completely new translation project and the hook and pull requests
will be sent to github
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2092#comment:6>
OSGeo <https://osgeo.org/>
