#2092: Install Weblate in Docker
Reporter: robe | Owner: robe
Type: task | Status: closed
Priority: normal | Milestone: Sysadmin Contract 2021-II
Component: Systems Admin | Resolution: fixed
Keywords: |
Comment (by dkastl):
Thank you, @robe !
I'm not sure what information is stored only on Weblate side, but
translations should backed up on Git repository side, if automation is
setup correctly.
I will make a test with the plugin, which is small and probably a good
project to try it out.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2092#comment:9>
OSGeo <https://osgeo.org/>
