#2092: Install Weblate in Docker
Reporter: robe | Owner: robe
Type: task | Status: closed
Priority: normal | Milestone: Sysadmin Contract 2021-II
Component: Systems Admin | Resolution: fixed
Keywords: |
Comment (by robe):
Okay made significant progress here.
I have set up https://github.com/postgis/postgis-workshops to use
https://weblate.osgeo.org for translation.
To do that (cause turns out on Github you can only have an ssh key
registered as deployment key only once -as Daniel discovered when he tried
to reregister the deployment key on his project).
1) I created a github account called osgeoweblate. Password info in
secure in file access/github.com
2) I had to give this new account write access to
3) On weblate for the postgis-workshop in my main component -
https://weblate.osgeo.org/settings/postgis-workshop/index/#vcs had to set
the push url to - git@github.com:postgis/postgis-workshops.git
I have similar set up with postgis on gitea, but only with a fork, cause
we still have transifex use there until we test the tires some more.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2092#comment:11>
OSGeo <https://osgeo.org/>
