#2122: Travis/GitLab/Jenkins badges not shown anymore on postgis/geos trac wiki
Reporter: strk | Owner: strk
Type: task | Status: new
Priority: blocker | Milestone:
Component: Trac | Keywords:
As reported in https://trac.osgeo.org/postgis/ticket/4019
some badges are not shown anymore on PostGIS wiki since the recent
upgrade.
I found the problem being with
crossorigin="anonymous"
Attribute being added to the {{{img}}} tag. This is done by Trac itself
because we surely haven't added that manually.
Example showing the fix: https://trac.osgeo.org/test.html
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2122>
OSGeo <http://www.osgeo.org/>
Component: Trac | Resolution:
Keywords: |
Comment (by strk):
There seem to be a trac configuration to lits safe origins:
https://trac.edgewall.org/wiki/TracIni#wiki-safe_origins-option
Any domain listed there ("*" allowed) would be rendered w/out
'crossorigin="anonyomous"'
I don't know why it was working before the upgrade, maybe the default
`render_unsafe_content` configuration for `[wiki]` section used to be true
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2122#comment:1>
Type: task | Status: closed
Component: Trac | Resolution: fixed
Keywords: |
Changes (by strk):
* status: new => closed
* resolution: => fixed
Comment:
`render_unsafe_content` is currently set to disabled/false for each
environment (rather than globally). No `safe_origins` is set. I've set
safe_origins to {{{*}}} globally and it fixed the problem (possibly
raising other problems but better discuss this separately)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2122#comment:2>
Keywords: |
Comment (by strk):
For the record, the global config change is in this commit:
https://git.osgeo.org/gitea/sac/tracsvn-etc-
trac/commit/6cd98916c548add96c5c69b714f863d82c66a1c4
(requires login and permission to view)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2122#comment:3>
Keywords: |
Comment (by strk):
And here's the possible commit which changed things between previous Trac
version and current:
commit 46f42cbc494991dcd3b87c63d60c48bc0020faac
Merge: 9d238d0 ab581b8
Author: jomae <jomae@af82e41b-90c4-0310-8c96-b1721e28e2e2>
Date: Wed Jun 14 03:22:34 2017 +0000
1.2.2dev: merge [16025] from 1.0-stable
git-svn-id:
http://trac.edgewall.org/intertrac/log:/branches/1.2-stable@16026
commit ab581b8f99a022be5049174e100d775e051a6426
Date: Wed Jun 14 03:19:01 2017 +0000
1.0.15dev: add `[wiki] safe_origins` option to avoid
`crossorigin="anonymous"` attribute (refs r15894)
git-svn-id:
http://trac.edgewall.org/intertrac/log:/branches/1.0-stable@16025
commit bc37331bd5264e4de9e31284b6de91975ccc7b81
Merge: 69d4755 1e3f7a2
Date: Fri May 12 08:23:27 2017 +0000
1.2.2dev: merge [15894] from 1.0-stable
git-svn-id:
http://trac.edgewall.org/intertrac/log:/branches/1.2-stable@15895
commit 1e3f7a291df40d67ec88c42ed88c42fc91ebe5bd
Date: Fri May 12 08:17:15 2017 +0000
1.0.14dev: avoid password prompt for cross-origin resources
git-svn-id:
http://trac.edgewall.org/intertrac/log:/branches/1.0-stable@15894
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2122#comment:4>
Keywords: |
Comment (by TemptorSent):
I believe safe_origins should be set to reflect the domains we actually
want remote data to be included from, such as secure.travis-ci.org,
*.osgeo.org, *.postgis.net, etc. The crossorigin="anonymous" tag mitigates
user tracking an phishing attacks by causing the request to be made
without submitting cookies, credentials, or other identifiable
information, which an untrusted remote host may be able to use in
nefarious ways.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2122#comment:5>
Keywords: |
Comment (by strk):
According to specs, 'crossorigin' img attribute (added in HTML5) should
have to do with using the image as a canvas, but not prevent its loading.
See https://www.w3schools.com/tags/tag_img.asp
Instead browsers are not loading the resource at all.
There are 24 trac instances under OSGeo: https://trac.osgeo.org/ - we
don't want to restrict the possibility to load images from the network to
an handful of "trusted" sites, and why should we trust travis-ci.org
anyway ?
That said, if the servers serving the images would allow cross-origin use,
as it would make sense for public badges, this problem would not exist. We
can fix the ones under our control but we cannot fix the travis/gitlab-ci
ones.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2122#comment:6>
Keywords: |
Comment (by martin):
Great, thanks !
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2122#comment:7>
