#2128: Login required for svn checkout of GRASS GIS
Reporter: wenzeslaus | Owner: sac@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Systems | Keywords: login, subversion, svn,
Admin | credentials, grass
What happens:
Anonymous `svn checkout` of GRASS GIS requires credentials.
Expected behavior:
No credentials required for reading.
How to reproduce:
Run Ubuntu in Docker:
docker run -it --rm ubuntu
Then install Subversion and update certificates:
apt update -y
apt install -y subversion ca-certificates
svn checkout https://svn.osgeo.org/grass/grass/trunk
Alternatively, run Fedora in Docker:
docker run -it --rm fedora bash
yum update -y
yum install -y subversion
In both cases I get:
Authentication realm: <https://svn.osgeo.org:443> OSGeo Login
Password for 'root':
I observed the same behavior on two computers (Ubuntu, no Docker).
In all cases authentication request comes after a random number of
downloaded files, not at the beginning or after a specific file.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2128>
OSGeo <http://www.osgeo.org/>
Priority: blocker | Milestone:
Component: Systems Admin | Resolution:
Keywords: login, subversion, svn, |
credentials, grass |
Changes (by strk):
* priority: normal => blocker
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2128#comment:1>
Priority: blocker | Milestone: Sysadmin
| Contract 2018
Changes (by strk):
* milestone: => Sysadmin Contract 2018
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2128#comment:2>
Reporter: wenzeslaus | Owner: martin
Type: defect | Status: assigned
| Contract 2018
Changes (by martin):
* owner: sac@… => martin
* status: new => assigned
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2128#comment:3>
Priority: blocker | Milestone: Sysadmin Contract
| 2018-I
Comment (by martin):
To a certain degree this error occurs randomly (!)\\
After transferring a varying number of files, Apache kicks in claiming
"client denied by server configuration".
Actually, Apache-DAV-SVN is authenticating access to every single file in
the SVN-repo individually, causing dozends of auth requests per second
just for a single checkout. Now, since checkout over my slow 2 Mbit/s line
at home works flawlessly, I'd suspect an overflow of authentication
requests being the root cause.
The Apache "mod_ldap" connector allows caching LDAP requests - in fact it
does by default, but may require some tuning. I'll add some custom setting
and will re-check later today or tomorrow if that makes a difference. If
it does, then I'd also suspect the overall SVN performance to improve.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2128#comment:5>
| 2018-I
My very first test on a well-connected machine worked quite nicely after
the change:
tracsvn:~# cat /etc/apache2/mods-available/ldap.conf\\
LDAPSharedCacheSize 1000000\\
LDAPCacheEntries 4096\\
LDAPOpCacheEntries 4096\\
Please test and respond.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2128#comment:6>
| 2018-I
Comment (by wenzeslaus):
Sorry, still the same here (99.4 Mbps download as measured by Google)
using the tests above.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2128#comment:7>
| 2018-I
Comment (by robe):
FWIW I was having the same issue about the time this ticket was reported
with GDAL.
For GDAL SVN I don't have commit access to I pull annonymously. It was
prompting me for password to do an svn update or svn checkout. It seems
fine now.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2128#comment:8>
| 2018-I
Comment (by strk):
Can mod_evasive have a role here ? Too many consecutive requests ?
I remember SVN checkouts made lots of PROPFIND to the very same URL.
But any such block should not prompt for a password: is a password
prompt what the original report complains about ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2128#comment:9>
| 2018-I
Replying to [comment:9 strk]:
> is a password
Yes, this is what I see (using the Docker image above):
$ svn checkout https://svn.osgeo.org/grass/grass/trunk
A trunk/general
A trunk/general/g.rename/testsuite/test_overwrite.py
A trunk/general/g.rename/main.c
A trunk/general/g.pnmcomp/Makefile
A trunk/general/g.dirseps/g.dirseps.html
A trunk/general/g.proj/g.proj.html
A trunk/general/g.proj/create.c
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2128#comment:10>
| 2018-I
Comment (by robe):
okay I just experienced the same issue doing a checkout of gdal trunk.
I think I thought it was fixed, because I can do an svn update fine after
even though I never successfully authenticated doing svn checkout.
When I try to type in my user name and password (which doesn't have write
rights to gdal repo if keeps on prompting for password, and finally ends
with too many tries).
So guess it's still an issue.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2128#comment:11>
| 2018-I
Comment (by EliL):
I also just experienced this doing a checkout of gdal. Checkout might
make more requests than update.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2128#comment:12>
| 2018-I
I ran a couple of consecutive tests and, indeed, mod-evasive makes a
difference.
Its config says: The client will be added to the blocking list for one
minute if it exceeds 50 requests per second.\\
Now that we're running a significantly updated version of SVN - upgraded
from 1.5.1 to 1.8.10 - the server probably responds a lot faster than it
did before and mod-evasive kicks in.
Surprisingly a couple of hosts have been whitelisted in mod-evasive -
looks like the issue might be a known buddy.
I'm now leaving mod-evasive disabled so everybody can test and - maybe -
later start re-enabling and tuning the parameters. On the other hand:
Increasing thresholds will almost make mod-evasive useless anyway.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2128#comment:13>
| 2018-I
I can report a successful checkout using the Docker test above (at 46.5
Mbps).
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2128#comment:14>
| 2018-I
Thanks for testing.\\
I've now re-enabled mod-evasive but I've also increased the "hits per host
and second" threshold by four times (value of 200 now). Would you please
test and report again ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2128#comment:15>
| 2018-I
Further analysis revealed, that 200 hits per host and second won't
suffice, threshold now increased to 450.\\
Hey, this means that our SVN service is capable of serving almost 450 hits
per second ! ![:wink: :wink:](/images/emoji/twitter/wink.png?v=12)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2128#comment:16>
| 2018-I
Works for me (Docker test, at 46.5 Mbps).
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2128#comment:17>
Type: defect | Status: closed
| 2018-I
Component: Systems Admin | Resolution: fixed
Changes (by robe):
* status: assigned => closed
* resolution: => fixed
Comment:
I was able to do a full checkout of GDAL trunk without issues now.
I'm going to consider this fixed and closed.
Great job Martin!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2128#comment:18>
