#2131: New Wordpress instance for GRASS GIS project
Reporter: neteler | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords: wordpress WP
The GRASS GIS project needs to re-do their web site (the current CMS is
not even with a responsive theme) and would be happy to get a WP instance.
From IRC, SAC meeting 15 Mar 2018:
"[23:05] <robe2> You can even write I promised to set it up on web18a
which is already all configured for wordpress"
''Near future:''
* Once set up and populated with content we may switch over the DNS to
let grass.osgeo.org reach the WP instance on web18a.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2131>
OSGeo <http://www.osgeo.org/>
Reporter: neteler | Owner: robe
Component: Systems Admin | Resolution:
Keywords: wordpress WP |
Changes (by robe):
* owner: sac@… => robe
Comment:
Markus,
I forgot to ask what you want as the domain name for it?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2131#comment:1>
Comment (by robe):
as noted on irc I'll call this grass_temp.osgeo.org
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2131#comment:2>
Comment (by neteler):
Probably better: staging.grass.osgeo.org
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2131#comment:3>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Done -- I added your OSGeo account as an administrator. You should have
gotten a confirmation email.
https://staging.grass.osgeo.org
You'll probably want to add a local admin account for yourself so that you
can fiddle with the ldap settings if you need to. It's a bear bones
install, plus the WPAuthDir plugin we use for LDAP authentication. I
copied the settings from www.osgeo.org, so you may want to fiddle with it
a bit if you only want GRASS members to be able to log in. Right now it
will let an OSGeo member login with Subscriber role (minimalist role).
Feel free to reopen this ticket if I missed anythign.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2131#comment:4>
Thanks to much, robe!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2131#comment:5>
