#2132: Mail for osgeo
Reporter: cvvergara | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
About mail for osgeo:
- Some like president@osgeo.org are set up as redirect.
- cannot send email with this identity due to some change
infrastructure.
- Any limit on number of accounts, .. maybe 50?
First step:
Ask SAC the possibility of creating such accounts
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2132>
OSGeo <http://www.osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by msmitherdc):
Google for nonprofits unavailable for osgeo as they only allow 501c3 and
we are 501c4
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2132#comment:1>
Keywords: |
Comment (by Delawen):
Copying from mailing list:
Summarize a bit:
Right now there is an aliases on the president at osgeo email and it
redirects properly to my email. That's working fine.
We are on the F2F Board meeting and we discussed that it made sense to
be able to send emails with that address too. Plus, if we can keep a
historical record of conversations, it would be good. For example, I
have no idea what previous presidents have discussed and if there is
some kind of pending conversation in the middle.
Also, at this point, all emails should be redirected only to me. I saw
something on the IRC that there is more than one aliases, but that
should be legacy lines that shouldn't be there anymore.
So a proper email instead of an alias would be much better: being able
to send emails and keep historical email record.
Even if I use gmail right now, I'm fine with using any other web mail
or desktop client for using the president email. If it has some kind
of smtp or similar, better, but if it has to be a webmail, I can
accommodate.
Let me know if this is possible.
Cheers and thanks for your good work!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2132#comment:2>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by jef):
* status: new => closed
* resolution: => fixed
Comment:
osgeo6.osgeo.osuosl.org not supports SMTP AUTH - so you can use it as a
outgoing smtp server with osgeo.org sender addresses.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2132#comment:3>
Type: task | Status: reopened
Keywords: |
Changes (by Delawen):
* status: closed => reopened
* resolution: fixed =>
Comment:
Sorry to reopen this but I am not sure how am I supposed to connect. Is it
using my LDAP OSGeo account? If that's the case, it's not working.
Trying SMTP:
host: osgeo6.osgeo.osuosl.org
Port: 587
Username: Delawen (also tried "delawen")
Password: LDAP password
Connection Type: SSL/TLS (also tried "none", "STARTTLS")
Maybe I need an account on that server?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2132#comment:4>
Keywords: |
Also, the default port seems closed, maybe I'm using the wrong one?
$ telnet osgeo6.osgeo.osuosl.org 587
Trying 140.211.15.3...
telnet: Unable to connect to remote host: Connection refused
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2132#comment:5>
Keywords: |
Changes (by jef):
* status: reopened => closed
Comment:
smtp (port 25) would have worked - submission (port 587) now also works.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2132#comment:6>
Keywords: |
* Attachment "FailedRCPT.png" added.
Keywords: |
* Attachment "loginFailed.png" added.
Keywords: |
* Attachment "config.png" added.
Keywords: |
Now the port works but I still can't send emails. I think I tried all the
combinations the server says that are supported, but with no success.
Probably it is a missing config, but I can't find it. Can you help me?
Sorry for the attachments in Spanish:
If I tried some kind of authentication:
[[Image(loginFailed.png)]]
(using my LDAP user)
If I don't do any authentication:
[[Image(FailedRCPT.png)]]
[[Image(config.png)]]
Also, did you fix the alias so it only redirects to my email
(delawen@gmail.com or delawen@osgeo.org)?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2132#comment:7>
Keywords: |
Comment (by jef):
Try again please.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2132#comment:8>
Keywords: |
Comment (by jef):
president@osgeo.org is now an alias for delawen@osgeo.org (previously it
was also pointing at helena.mitasova@osgeo.org, tzotsos@osgeo.org and
jmckenna@osgeo.org; per #2091).
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2132#comment:9>
Keywords: |
Still doesn't work. I am trying with my LDAP user/pass (Delawen), same as
for example on this trac.
Just to confirm: what is the configuration I should use and what username
and password?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2132#comment:10>
Keywords: |
Now the error is that I get prompted the username and password on a loop,
so my guess is that it is not the LDAP user and password. But then, which
one?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2132#comment:11>
Keywords: |
Comment (by jef):
try again please - you've been added to the shell group
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2132#comment:12>
Keywords: |
Worked great, thanks!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2132#comment:13>
