#2134: FunToo Container, whitelist for LDAP
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
palica of Funtoo has setup an OSGeo container we can create subcontainers.
I'd like to configure LDAP ssh on it, so would like the IP whitelisted
172.97.103.135 (osgeo.host.funtoo.org)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2134>
OSGeo <http://www.osgeo.org/>
Priority: normal | Milestone: Sysadmin Contract 2018-I
Component: Systems Admin | Resolution:
Keywords: |
Changes (by strk):
* milestone: => Sysadmin Contract 2018-I
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2134#comment:1>
Keywords: |
Comment (by robe):
side note, I disabled root login on this box, and created an account
tech_dev@osgeo.host.funtoo.org
with sudo access.
of which I added ssh keys for martin, strk, TemptorSent, wildintellect.
Can you all verify you can log in. Once the IP is whitelisted, I'll
configure the ssh LDAP authentication and we can start setting up services
with ldap authentication enabled.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2134#comment:2>
Reporter: robe | Owner: strk
Priority: normal | Milestone: Unplanned
Keywords: |
Changes (by robe):
* owner: sac@… => strk
* milestone: Sysadmin Contract 2018-I => Unplanned
Comment:
Thanks strk for taking care of this. Will report if we have issues.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2134#comment:3>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2134#comment:4>
