#2136: Make svn.osgeo.org/gdal read-only
Reporter: rouault | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
Per https://trac.osgeo.org/gdal/wiki/rfc71_github_migration , the GDAL svn
repository will now be unused. Could you please turn write rights into it
off?
Thanks
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2136>
OSGeo <http://www.osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by martin):
Accomplished by removing the group rw-permissions from the respective
authz file.\\
Apparently the same method was used on the QGIS SVN repo beforehand.
Please check and confirm.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2136#comment:1>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by rouault):
* status: new => closed
* resolution: => fixed
Comment:
I confirm I can no longer commit in GDAL SVN. Thanks !
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2136#comment:2>
