#2147: Unable to upload a custom word-press theme to staging word-press instance
for FOSS4G2018 Dar es salaam website
Reporter: mloweedgar | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords: word-press
We would like to upload a custom word-press theme for FOSS4G2018 Dar es
salaam website to a staging instance at
[https://staging.2018.foss4g.org], but we can not upload the theme due to
upload size limit issue. Could you please increase upload size limit so as
we can be able to upload the theme.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2147>
OSGeo <http://www.osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: word-press |
Comment (by robe):
I increased the max upload size to 600M. Can you try again and see if
that fixes your problem. If it doesn't let me know the size of the file
you are trying to upload.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2147#comment:1>
Reporter: mloweedgar | Owner: robe
Changes (by robe):
* owner: sac@… => robe
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2147#comment:2>
Comment (by mloweedgar):
Thank you robe, we have been able to upload the theme.We still have one
more request, we are requesting FTP credentials so as we will be able
download, change and upload individual files of our custom theme. Thanks
in advance.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2147#comment:3>
Comment (by robe):
I'm thinking if it would be better to do via Git. I can set up a cron
job to pull the files every 5 minutes or so. That would be better since
you can assign permissions as needed to others.
I have the site under a private git repo already, though I selectively
only committed some files since I didn't want to bother with plugins that
are constantly updated.
If you log into https://git.osgeo.org/gitea I can give you access to that
git repo like I already had done for Tim. I should probably move into
it's own org as well.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2147#comment:4>
Thank you robe, using git will be the best option, I would like to know
what information should I provide, so as you can give me access to the
repo. I was able to login into https://git.osgeo.org/gitea, and created
this repository
https://git.osgeo.org/gitea/mloweedgar/foss4g2018_dar_wordpress_theme
which contains the custom theme we have developed.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2147#comment:5>
Comment (by robe):
moloweedgar,
I've added you to this repo as a collaborator with edit rights.
I had checked in what's on server - the theme, so I presume it's the same
as what you have in the repo.
https://git.osgeo.org/gitea/osgeo/FOSS4G2018_WordPress
Can you see if you can access the repo? If you can and can edit I'll work
on setting up a cronjob later today to pull any changes from the git repo.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2147#comment:6>
Hi robe,
Thank you for giving me collaborator access to the repo. we have been able
to access the repo and we have done some edits on the theme. we think you
can now set up a cronjob to pull my changes from the repo. Thank you.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2147#comment:7>
Comment (by robe):
mloweedgar,
Thanks for confirming. Will try to get to it later today.
I presume you made local edits via wordpress and I can discard those, repo
is up to date? getting a merge conflict.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2147#comment:8>
Comment (by robe):
Okay I have set up cronjob to poll every 5 minutes. So whatever changes
you make that repo should appear on site within 5 minutes of change.
I was thinking of putting in a reset --hard in case if you make local
changes for testing, but decided against that. So try to only make
changes to the theme via the git repo.
Feel free to reopen this if you still have issues.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2147#comment:9>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Changes (by robe):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2147#comment:10>
