#215: MySQL Binary Logs Fill Disk on OSGeo2
Reporter: warmerdam | Owner: sac@lists.osgeo.org
Type: task | Status: new
Priority: major | Component: SAC
Keywords: mysql |
This directory appears to be full of binary logs on osgeo2, similar to the
issues on osgeo1 mentioned in #176.
[root@osgeo2 etc]# du /var/lib/mysql/.a
177892908 /var/lib/mysql/.a
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/215>
OSGeo <http://www.osgeo.org/>
On Sun, Mar 09, 2008 at 02:00:27PM -0000, OSGeo wrote:
I don't see you in IRC. Would you like me to take care of cleaning up the
mysql logs problem? I'm just worried about us colliding on this issue.
For clarification: I've been moving all the mysql-bin. files into a
(hand-made) subdir .a to see, if MySQL will resume running afterwards.
In other words: To see if MySQL really still needs these files or if it
can live without. I simply didn't know better than just trying it out.
If you came to the conclusion that MySQL does _not_ need these old
files (at least this is my conclusion) then simply remove the whole .a/
subdir and you'll be fine for a while.
I have to leave urgently (having a concert this evening: Brahms
Requiem), therefore I don't have the time to show up on IRC,
Martin.
Unix _IS_ user friendly - it's just selective about who its friends are !
Martin,
Thanks for your work on this. I have cleaned out the logs, and disabled
binary logging on osgeo2 (as we had previously for osgeo1). Details in
for those interested.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | President OSGeo, http://osgeo.org
