#2154: Please repoint staging.2018.foss4g.org to 2018.foss4g.org
Reporter: timlinux | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords: DNS
Thanks so much for helping us get a Wordpress instance set up. We have
everything configured now and would like to go live with it. Could you
please epoint staging.2018.foss4g.org to 2018.foss4g.org?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2154>
OSGeo <http://www.osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: DNS |
Comment (by timlinux):
Hi can I just check if anyone has noticed this issue? It would be great to
get the new site online.
Also, could you please point the staging url to the current site so
2018.foss4g.org points to the wordpress site you set up
staging.2018.foss4g.org points to our current live site (52.28.51.102)
Thanks so much!
Regards
Tim
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2154#comment:1>
Keywords: DNS |
Comment (by robe):
I'm on it now. I'll create a new site based on your staging one so you
can still have a staging.
I'll let you know once I have in place.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2154#comment:2>
Keywords: DNS |
Comment (by robe):
Okay repointed now. I still have git repo only feeding to staging.
To feed to prod as well, I'm going to put in a text file in git for prod.
So would be something like prod.txt.
So if the file is present, it will push changes to prod as well and if
the file is not present changes will only go to staging.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2154#comment:3>
Keywords: DNS |
Comment (by robe):
forgot to mention, it might not have propagated for you yet since you
visit the site often.
Once it's propagated. You should be able to access it via
https://2018.foss4g.org/
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2154#comment:4>
Keywords: DNS |
Comment (by robe):
Okay I have the prod.txt/dev.txt switch file in place now.
I see though that you guys are making content changes in staging though
and I have the two databases different at the moment.
e.g. this page exists in Staging, but not in prod.
https://staging.2018.foss4g.org/about/#Dar%20LOC
, but not in
https://2018.foss4g.org/about/#Dar%20LOC
Should I reupdate the production database.
The staging should only be used for testing themes before deployment to
production as such a change could break the site.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2154#comment:5>
Keywords: DNS |
Comment (by strk):
May I suggest to map git branches to staging/production
instead of a file ?
I'm thinking it would be hard to work on a staging change
while at the same time having the need to fix a typo in
production otherwise.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2154#comment:6>
Keywords: DNS |
Thanks so much for this @robe!
@Edgar can you document the workflows somewhere? If Regina has set up the
staging instance for us we don't need to self manage one on the Amazon Web
Server from Ragnvald so lets rather shut that down and use the OSGEO
provided one.
@Edgar can you also comment if the git workflow is clear for you?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2154#comment:7>
Keywords: DNS |
Comment (by mloweedgar):
@Tim I have understood the both work flows. I think we are going for the
branching work flow that is having staging and production branches. @robe
we would prefer using branches, my question is, should create the
staging/production branches or you are going to do that for us. my
apologizes for writing this comment late.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2154#comment:8>
Keywords: DNS |
Comment (by robe):
You can go ahead and branch and name as you see fit. Just let me know
when you are done and then I'll change the pull scripts accordingly to
point to the respective branches.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2154#comment:9>
Keywords: DNS |
Comment (by beaty):
Thanks all for pushing this forward. @robe we have created staging and
production branches which will be used to push changes to the staging and
production(live) sites respectively. you can now change the pull scripts
accordingly to the respective branches @robe. Thanks in advance.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2154#comment:10>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: DNS |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Okay I have 2018.foss4g.org now following the production branch and
staging.2018.foss4g.org now following the staging branch. I've deleted
the dev.txt file to minimize on confusion and updated the READMEs to
reflect the new workflow.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2154#comment:11>
#2154: Repoint 2018.foss4g.org to new location and revise git pull to follow gitea
Keywords: DNS |
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2154#comment:12>
Keywords: DNS |
Thank you so much for your support Regina!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2154#comment:13>
