#2179: Deployment of LimeSurvey on OSGeo servers
Reporter: vasile | Owner: sac@…
Type: task | Status: new
Priority: major | Milestone:
Component: Systems Admin | Keywords:
Hi SAC members,
During the face2face meeting in Bonn, OSGeo board decided to extend the
use of electronic voting system to charter members to avoid the "spam" on
our mailing list. The board also decided to implement the electronic
voting system on OSGeo's infrastructure (until now was hosted on various
friend organizations). That being said, I would like to ask SAC to deploy
a LimeSurvey (https://www.limesurvey.org/stable-release) instance on our
servers.
Thank you,
Vasile
CRO
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2179>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by wildintellect):
This is a great scenario for use of a container. Can we test this on
Funtoo for now while we setup OSGeo7. Elections are soon so this is
somewhat urgent.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2179#comment:1>
Keywords: |
Comment (by vasile):
I urge SAC to deploy LimeSurvey on our infrastructure in the next 10 days.
Otherwise we will not be able to use it for this year elections.
Vasile
CRO 2018
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2179#comment:2>
Keywords: |
Changes (by strk):
* cc: TemporSent (added)
Comment:
TemporSent, any idea about setting up LimeSurvey in an LXD container ?
Otherwise we may try docker ?
https://www.limesurvey.org/es/foro/news/98178-lime-survey-container-on-
docker-ready-to-run
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2179#comment:3>
Keywords: |
Changes (by TemptorSent):
* cc: robe2 (added)
Comment:
Now in process of adding lxd container for limesurvey on funtoo host
container. We need to identify who will be acting as admin for this
instance and determine what additional configuration may be required.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2179#comment:4>
Keywords: |
CRO should be the admin person (this year is me). A crucial aspect is to
configure the email in ksuch way that messages from cro@osgeo.org to
accounts like Yahoo or Gmail don't end-up in Spam folder.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2179#comment:5>
Keywords: |
Comment (by robe):
vasile,
We've finished setting up limesurvey on funtoo.
I added your ldap account as an administrator
Login here:
https://limesurvey.osgeo.org/admin/index.php
Please give it a try and see if it works okay for you. Make sure to use
LDAP database for login.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2179#comment:6>
Keywords: |
I did. Is working! Thank you so much!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2179#comment:7>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
vasile I assume you are all set for now. Feel free to reopen if you need
anything.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2179#comment:8>
Keywords: |
Comment (by robe):
For completeness there was an issue with the mailing from limesurvey
which got carried over to here:
https://git.osgeo.org/gitea/osgeo/todo/issues/20
We believe the issue is now resolved.
To resolve (quick fix, more involved fix to be implemented at our leisure
would be to get authentication working) here are the steps SAC took:
1) Add the limesurvey.osgeo.org (aka funtoo.osgeo.org) IP to
/etc/postfix/main.cf postfix file in osgeo6 in the mynetworks attribute -
so added at end was [172.97.103.135/32
2) postfix reload # so new changes took effect
3) git add .. and commit with what was changed - this is by the way not
in gitea, it's just a local standalone git it seems and there are many
uncommitted files ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
4) Did some tests with nc to do a commandline email on the
limesurvey.osgeo.org and cofirmed I received it.
5) On Limesurvey change the Mail to use SMTP (mail server only) no
authentication since the ip has been whitelisted
6) Vicky set up a test survey and was able to send it to herself, complete
and receive a confirmation notice.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2179#comment:9>
