#2182: Strange message from git.osgeo.org after commit
Reporter: dbaston | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
A commit push succeeds but gives some error messages implying that it
didn't:
Username for 'https://git.osgeo.org': dbaston
Password for 'https://dbaston@git.osgeo.org':
Counting objects: 4, done.
Delta compression using up to 8 threads.
Compressing objects: 100% (4/4), done.
Writing objects: 100% (4/4), 406 bytes | 0 bytes/s, done.
Total 4 (delta 3), reused 0 (delta 0)
remote: Error: Unable to get database connection within 0 seconds.
(OperationalError: fe_sendauth: no password supplied
remote: )
remote: <html><head><meta http-equiv='refresh'
content='1;url=/login?from=%2Fview%2FGEOS%2Fjob%2F%2FGEOS_Master%2FbuildWithParameters%3Ftoken%3Dge0S'/><script>window.location.replace('/login?from=%2Fview%2FGEOS%2Fjob%2F%2FGEOS_Master%2FbuildWithParameters%3Ftoken%3Dge0S');</script></head><body
style='background-color:white; color:white;'>
remote:
remote:
remote: Authentication required
remote: <!--
remote: -->
remote:
remote: </body></html>
remote:
remote:
remote: <!--
remote: -->
remote:
Thanks for letting us know
To https://git.osgeo.org/gitea/geos/geos.git
311989f..c13f075 master -> master
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2182>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by strk):
commit c13f07516098e0cb4b4fe5c58c678d27b38b580e landed
in the repository, so I guess the error was sent by
a post-receive hook.
One thing done by it is invokation of trac-admin.
For trac.osgeo.org we have trac run under the name
of "www-data" user, which sets the password in its
.pgpass file, but Gitea runs as user "git", which didn't
have the .pgpass file. Now it does.
Can you please check if the problem is now fixed ?
Ideally we should update some wiki page about this
(osgeo-sac)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2182#comment:1>
Keywords: |
Comment (by dbaston):
Now I get this message. Not sure if this is expected.
Counting objects: 11, done.
Compressing objects: 100% (11/11), done.
Writing objects: 100% (11/11), 832 bytes | 0 bytes/s, done.
Total 11 (delta 10), reused 0 (delta 0)
remote:
remote:
remote: <!--
remote: -->
remote:
remote:
remote:
remote: <!--
remote: -->
remote:
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2182#comment:2>
Keywords: |
Comment (by strk):
Sounds like Jenkins needs some love.
Regina, can you fix this one ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2182#comment:3>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by strk):
* status: new => closed
* resolution: => fixed
Comment:
Should be fixed now, that error was from Jenkins, which a post-update hook
was hitting on an obsoleted URL. I dropped hitting that URL completely, as
now that communication is done via web-hooks instead. See
https://git.osgeo.org/gitea/geos/geos-git-
hooks/commit/e4c31e33c38c425d737dece6a6268d4d455a0eae
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2182#comment:4>
