#2183: geotools release failed to deploy to maven repository
Reporter: jive | Owner: sac@…
Type: task | Status: new
Priority: blocker | Milestone:
Component: Systems Admin | Keywords:
This is a follow up to #2180 tracking recent changes to geotools maven
repository, this issue was closed when I could deploy a single jar to the
webdav server using my OSGeo userid credentials.
Our Jenkins build box (build.geoserver.org) failed to deploy the most
recent 19.2 release:
* https://build.geoserver.org/view/release/job/geotools-release-
publish/104/console
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ geotools ---
WAGON_VERSION: 1.0-beta-2
Uploading:
dav:http://download.osgeo.org/webdav/geotools/org/geotools/geotools/19.2/geotools-19.2.pom
4 KB
8 KB
12 KB
16 KB
20 KB
24 KB
28 KB
32 KB
36 KB
40 KB
44 KB
48 KB
52 KB
56 KB
60 KB
64 KB
68 KB
72 KB
75 KB
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-
plugin:2.7:deploy (default-deploy) on project geotools: Failed to deploy
artifacts: Could not find artifact org.geotools:geotools:pom:19.2 in osgeo
(dav:http://download.osgeo.org/webdav/geotools/) -> [Help 1]
[ERROR]
I wonder if the geotools credentials used by this machine #1546 are not
functioning, or if we could look at the access logs and watch the build
server try to connect in order to learn what credentials are being used.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2183>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by jive):
Marking this issue as blocker as it is preventing the scheduled geotools
19.2 release.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2183#comment:1>
Keywords: |
Comment (by jive):
Note "geotools" user disabled in may, see http://osgeo-
org.1560.x6.nabble.com/GeoTools-GeoServer-
Meeting-2018-05-29-td5365942.html
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2183#comment:2>
Keywords: |
Comment (by jef):
Retry please.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2183#comment:3>
Keywords: |
Comment (by jive):
Retried, https://build.geoserver.org/job/geotools-release-
publish/106/console
And it is working!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2183#comment:4>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by jive):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2183#comment:5>
Keywords: |
Comment (by jef):
Fixed in https://git.osgeo.org/gitea/sac/download-apache-
config/commit/ca578f3bd1e947e84ed15e3b65024c660403aeb1
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2183#comment:6>
