#2198: Trac Login issue from 152.7.255.x
Reporter: wildintellect | Owner: sac@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
As reported via direct email.
I'm getting back to issue which I originally mentioned in "It seems that
NCSU IP is blocked in Trac". Trac (/grass, /osgeo, ...) logs me out few
moments after logging in. I can log in but when I reload the page (or
click
a link), I'm logged out again. This happens to me at North Carolina State
University network. There were problems with submitting to Trac from NCSU
in the past because of the spam filter settings, so I would assume now
that
the problem is again in Trac. Probably irrelevant, but I can use Internet
website with login in general, e.g. Gmail for sending this email.
When I go to various "get my IP" pages, I get these:
152.7.255.195
152.7.255.196
152.7.255.197
152.7.255.199
152.7.255.203
Please, let me know what else to provide.
Vaclav
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2198>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
Is this still an issue?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2198#comment:1>
Type: defect | Status: closed
Component: Systems Admin | Resolution: worksforme
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => worksforme
Comment:
Assume whatever this was is fixed as did not hear back.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2198#comment:2>
Keywords: |
Comment (by wenzeslaus):
Unfortunately, it is still an issue (at least it was week or so ago). I
missed comment:1 and, since it is not working, I can't really test it and
respond here at the same time.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2198#comment:3>
Keywords: |
Comment (by strk):
Vaclav, when you say "get my IP" gives you different IPs, that makes me
think that our service may be checking for client IP in order to verify
the login cookie is valid or not. Do you have this problem only with Trac
or also with https://git.osgeo.org/gitea or svn.osgeo.org ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2198#comment:4>
