#2239: OSGeo 7 ldap ssh access
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
I created an lxd container
outlined here:
https://git.osgeo.org/gitea/sac/osgeo7/wiki/Debian-10-container-with-LDAP-
SSH-%28WORK-IN-PROGRESS%29
That has Debian 10 installed, and LDAP SSH libs, and configured to connect
with ldap.osgeo.org.
I however have not been successful being able to log in with it using my
ldap account.
I suspect it's something really simple I am missing.
The Ldapsearch stuff works fine. So does
getent passwd <someldapuser>
Usually when that works all is set.
The moved things around quite a bit in debian 10 for ldap, so it might be
just a file config I am missing. Cause things I normally put in one file
had to be in a different one.
This I was hoping would serve two purposes
1) Be a skeleton for setting up debina with ldap / ssh access
2) Eventually build a DMZ container that people would need to log into
first to access the other containers.
I'm going to try next to build a debian 9 container instead and do the
same to rule out just an issue with how they changed ssh/ldap in debian
10.
I had tried an ubuntu 18.04 earlier and didn't even get as far with it as
I did with this debian10. Both have this extra systemd stuff which
confuses me.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2239>
OSGeo <https://osgeo.org/>
