#2243: Upgrade to nextcloud 15.0.0.2
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords: nextcloud
We are running nextcloud 15.0.0 and 15.0.0.2 came out a couple of days
ago. It doesn't have that many bug fixes, but the 15.0.0.1 version does
have a lot of bug fixes.
I did an experimental upgrade and it will require probably about 30minutes
- 1 hour of downtime.
They have an online upgrade which I tried but it timed out doing backup
etc, and since we don't really need our data backed up since I can
snapshot the container before upgrade, seems better to go with the manual
upgrade.
I'm also thinking of moving the data folder out of nextcloud folder and
have on same level
I took the defaults during install which created a path like this:
/var/www/nextcloud
/var/www/nextcloud/data
I'd like to change it to this:
/var/www/nextcloud
/var/www/nextcloud-data
Main reasons for changing it, is
1) I think it's better to not have the data in the web folder just in case
their is na nginx misconfiguration and it makes that exposed.
2) During these upgrades the upgrade steps are to
mv nextcloud nextcloud-old
and then copy/move over the data folder and any 3rd party apps you may
have.
I would do the move since I would do a snapshot of the vm anyway before
hand.
I'd much rather not having to worry about moving/copying the data folder
back in place.
I've taken a backup of the nextcloud image and other containers until we
have the general backup routine sorted out.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2243>
OSGeo <https://osgeo.org/>
