#2247: Rename aust-nz@lists.osgeo.org to osgeo-oceania@lists.osgeo.org
Reporter: camerons | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
OSGeo SAC,
Our Aust-NZ (Australia/New Zealand) OSGeo community has unanimously
accepted [1] a motion to rename our email list from aust-
nz@lists.osgeo.org to osgeo-oceania@lists.osgeo.org.
Could you please put this in place for us.
If it helps, you might want to check how this was done for the OSGeoLive
list, as per: https://trac.osgeo.org/osgeo/ticket/2146
Thanks, Cameron Shorter - board member of the new OSGeo Oceania local
chapter, and one of the founders of OSGeo Aust-NZ.
[1] https://lists.osgeo.org/pipermail/aust-nz/2019-January/001976.html
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2247>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by camerons):
Actually, can I ask you to hold on actioning this. I better ask our users
whether we want osgeo-oceania@lists.osgeo.org or oceania@lists.osgeo.org.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2247#comment:1>
#2247: Rename aust-nz@lists.osgeo.org to oceania@lists.osgeo.org
Keywords: |
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2247#comment:2>
Keywords: |
After voting, our osgeo oceania board has agreed that we would like to
rename aust-nz @ lists.osgeo.org to oceania @ lists.osgeo.org. Please
proceed when with processing this SAC request.
Thanks, Cameron
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2247#comment:3>
Reporter: camerons | Owner: jsanz
Component: Mailing Lists | Resolution:
Keywords: |
Changes (by jsanz):
* owner: sac@… => jsanz
* component: Systems Admin => Mailing Lists
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2247#comment:4>
Type: task | Status: closed
Component: Mailing Lists | Resolution: fixed
Keywords: |
Changes (by jsanz):
* status: new => closed
* resolution: => fixed
Comment:
@camerons I've renamed the list, please check if everything is going fine.
I also updated the Nabble archive to move from "Austrlia New Zealand" to
"Oceania" on the titles.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2247#comment:5>
Keywords: |
Comment (by jsanz):
New links:
- https://lists.osgeo.org/mailman/listinfo/oceania
- http://osgeo-org.1560.x6.nabble.com/OSGeo-Oceania-Local-
Chapter-f3721347.html
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2247#comment:6>
