#2248: Upgrade from dronie 1.0.0 rc3 to dronie 1.0.0rc5
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Unplanned
Component: Systems Admin | Keywords:
We are currently running drone server at https://dronie.osgeo.org
There are some improvements with relation to gitea introduced in 1.0.0 rc4
- https://discourse.drone.io/t/1-0-0-rc-4-release-notes/3458
For rc5, seems like mostly Kubernetes fixes.
https://discourse.drone.io/t/1-0-0-rc-5-release-notes/3540
The database is backward compatible with old, so I just need to upgrade
the docker images.
I'll also upgrade the dronie 1 clients which I think is currently:
dronie-server
ianna.postgis.net
debbie.postgis.net
(strk might have one too)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2248>
OSGeo <https://osgeo.org/>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
I've upgrade all of them to 1.0.0-rc5 (both server and agent)
I also pruned dronie server (21GB of images had already piled up and I
couldn't tell which were in use, so ran a prune to remove all not in use),
most were for dronie agent so they will end up being repulled.
Also did the same to ianna. She had even more images piled up like from
drone 05, 0.8, 0.81 among a bunch of other stuff.
I'll trigger some geos and postgis jobs to confirm all is working after I
reboot winnie.postgis.net (where ianna is housed).
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2248#comment:1>
Keywords: |
Comment (by strk):
Do we have another ticket to replace drone.osgeo.org
with the 1.0.0 version ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2248#comment:2>
