#2250: geotools.org shows as a directory listing
Reporter: jive | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
The GeoTools website (http://geotools.org) shows the directory listing,
rather than the contents of index.html
Index of /
[ICO] Name Last modified Size Description
[TXT] LICENSE.txt 2017-05-19 21:29 600
[ ] build.xml 2019-01-25 10:04 3.5K
[TXT] common.py 2019-01-25 10:04 6.9K
[ ] common.pyc 2019-01-25 19:49 1.8K
[DIR] developer/ 2017-05-19 21:29 -
[DIR] index/ 2017-11-11 20:54 -
[ ] pom.xml 2019-01-25 10:04 9.6K
[TXT] readme.txt 2017-05-19 21:29 2.8K
[DIR] site/ 2017-05-19 21:29 -
[DIR] src/ 2017-05-19 21:29 -
[DIR] target/ 2019-01-25 19:50 -
[DIR] themes/ 2017-05-19 21:29 -
[DIR] user/ 2018-06-26 21:54 -
[DIR] web/ 2017-05-19 21:29 -
Apache/2.4.10 (Debian) Server at geotools.org Port 80
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2250>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by jive):
Tracing this to a build failure at build.geoserver.org:
https://build.geoserver.org/view/geotools/job/geotools-master-docs/304/
+ scp web.zip geotools.org:/home/geotools/latest
+ cd ../../../target/user/html
/tmp/jenkins1478108414960067448.sh: line 17: cd:
../../../target/user/html: No such file or directory
Build step 'Execute shell' marked build as failure
Sending e-mails to: geotools-devel@lists.sourceforge.net
Finished: FAILURE
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2250#comment:1>
Keywords: |
Comment (by robe):
jive,
at a glance it doesn't look like the config of geotools has been change.
I do see that the documentRoot is set to:
/var/www/geotools/web
which when I look at the folder does have the directory of what is listed.
There is no index.html
I do see a web.old folder, which does have a index.html so wondering if
maybe that is what the directory used to be. Seems like if it got changed
it was done between January 25th and present and I would guess geotools
account made the change.
Does the geotools account push changes from jenkins to the geotools.org
website. Maybe it pushed in the wrong place or the wront thing.
stat web
shows this:
Size: 4096 Blocks: 8 IO Block: 4096 directory
Device: fd02h/64770d Inode: 103010454 Links: 10
Access: (0755/drwxr-xr-x) Uid: (15137/geotools) Gid: ( 100/ users)
Access: 2019-02-10 03:53:24.063960967 -0800
Modify: 2019-02-03 03:34:17.076135992 -0800
Change: 2019-02-03 03:34:17.076135992 -0800
stat web.old
shows this:
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2250#comment:2>
Type: task | Status: closed
Component: Systems Admin | Resolution: invalid
Keywords: |
Changes (by jive):
* status: new => closed
* resolution: => invalid
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2250#comment:3>
