#2258: www.osgeo.org upgrade cert to not use TLS cert
Reporter: robe | Owner: sac@…
Type: defect | Status: new
Priority: blocker | Milestone: Website v2.1
Component: Systems Admin | Keywords:
Got a note from Lets encrypt it's still using TLS cert.
Will update in a bit
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2258>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
For some reason the cert had not renewed though it is set to renew every
30 days so I manually renewed it. The cronjob looks okay.
I installed all updates on the server and rebooted.
certbot I confirmed is at 0.28.0 which is new enough to not use deprecated
TLS-SNI-01 method.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2258#comment:1>
Type: defect | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2258#comment:2>
