#2262: lists.osgeo.org doesn't accept mail from SMTP server without MX record
Reporter: Bas Couwenberg | Owner: jsanz
Type: defect | Status: new
Priority: major | Milestone:
Component: Mailing Lists | Keywords:
My mail to mapserver-dev is deferred because lists.osgeo.org doesn't
accept mail from my ISP SMTP server due to it not having an MX record in
DNS:
-Queue ID- --Size-- ----Arrival Time---- -Sender/Recipient-------
293C44C247C 6202 Sat Mar 16 12:33:30 sebastic@xs4all.nl
(Host or domain name not found. Name service error for name=smtp.xs4all.nl
type=MX: Host not found, try again)
mapserver-dev@lists.osgeo.org
-- 6 Kbytes in 1 Request.
It's kind of silly to require an outgoing SMTP server to have an MX record
which is only relevant for incoming mail. If you want an MX record you
need to check the domain of the sender in the From and/or Sender header.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2262>
OSGeo <https://osgeo.org/>
