#2266: Container for osgeo4mac
Reporter: fjperini | Owner: sac@…
Type: task | Status: new
Priority: major | Milestone:
Component: Systems Admin | Keywords:
Hello people!
As I mentioned here (see
https://lists.osgeo.org/pipermail/sac/2019-March/010760.html), we are
having problems with the Bintray service, this makes it impossible for us
to distribute the bottles and continue updating others.
We need a solution for this (and in a certain way urgently), and the
container would be very helpful.
If there is a possibility that they would give us one, we would be
grateful.
You can contact me at any time. Thank!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2266>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
Where are the files currently? they just need to be exposed via https
right?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2266#comment:1>
Yes!
Here: https://dl.bintray.com/homebrew-osgeo/osgeo-bottles
We would need the container with ssh access to automate everything.
El mar., 26 de mar. de 2019 a la(s) 15:14, OSGeo (trac_osgeo@osgeo.org) escribió:
Keywords: |
Comment (by robe):
right?
Sac mailing list
Sac@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/sac
Keywords: |
Comment (by fjperini):
Replying to [comment:1 robe]:
right?
Yes!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2266#comment:2>
Keywords: |
Comment (by wildintellect):
To clarify, ssh is to publish. The public would then download via https?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2266#comment:3>
Keywords: |
Yes, ssh to publish from CI and https to be able to access the bottles.
Replying to [comment:3 wildintellect]:
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2266#comment:4>
Priority: major | Milestone: Sysadmin Contract 2019-I
Keywords: |
Changes (by robe):
* milestone: => Sysadmin Contract 2019-I
Comment:
Just an update fjperini sent me his public keys.
I'm pretty much done with the server, but need to finish configuring the
website which I plan to do later tonight.
fjperini -- I'll send you an email when I have it all set so you can ssh.
You will be sshing with your fjperini ldap account and I will install your
keys there. Let me know if any other users need there keys installed.
We are standardizing on no more password logins and everything done with
ldap account + ssh keys.
The domain I will be setting up is called: bottles.download.osgeo.org
wildintellect -- I discussed with fjperini and he's okay with using some
other port besides 22 for ssh. So I don't need to use one of the extra
ips we have just yet.
when we finally reset up download.osgeo.org I suspect we'll have to use 22
so people don't have to change too much of their workflow, but perhaps
not.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2266#comment:5>
Ok, I’ll wait for the confirmation.
We will only use the ssh key that I passed to you. As for the administration, if you can also add to id: lpuerto, you are also part of the team.
Thank you!
El mié., 27 de mar. de 2019 a la(s) 15:05, OSGeo (trac_osgeo@osgeo.org) escribió:
Keywords: |
Changes (by robe):
- milestone: => Sysadmin Contract 2019-I
Comment:
I’m pretty much done with the server, but need to finish configuring the
fjperini – I’ll send you an email when I have it all set so you can ssh.
wildintellect – I discussed with fjperini and he’s okay with using some
other port besides 22 for ssh. So I don’t need to use one of the extra
when we finally reset up download.osgeo.org I suspect we’ll have to use 22
so people don’t have to change too much of their workflow, but perhaps
not.
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
This should be all set now
For ssh - bottle.download.osgeo.org (port: 50023)
The folder to put the files is /osgeo/bottle
The website I have currently accessible by both http and https
https://bottle.download.osgeo.org
Feel free to reopen this ticket if run into issues.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2266#comment:6>
