#2267: download.osgeo.org/stats/ returns 404
Reporter: kbevers | Owner: sac@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
When visiting https://download.osgeo.org/stats/ I get a "404 Not Found"
message. It is unclear to me if this site is even supposed to work, but it
is linked elsewhere on the [https://wiki.osgeo.org/wiki/VisibilityStats
OSGeo wiki] so I assume that should work. Also, I could really use some
stats on the download activity so I hope that this can be brought back to
life.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2267>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
I vaguely rememember someone complaining about how the logs were in plain
view. I thought this was the folder, so we may have closed it off.
That's just my vague memory which could be wrong.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2267#comment:1>
Keywords: |
Comment (by kbevers):
The folder doesn't seem to exists when I SSH into the download server, so
maybe this is just not supposed to be available anymore? If that is the
case the link from the OSGeo wiki needs to be removed.
In any case, I am still interested in getting my hands on download
statistics if they are available. What are my options?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2267#comment:2>
Keywords: |
Comment (by wildintellect):
It is not a folder, it's awstats script.
On http I'm getting a login prompt, but I'm not sure it's properly
configured.
On https I'm getting 404.
This is a bug, it should redirect to https and login should work with
OSGeo id. The correct config is probably missing from the https vhost.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2267#comment:3>
Type: defect | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
we don't have awstats installed so this is obsolete issue.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2267#comment:4>
