#2269: Switch OSGeo 7 to use snap package for lxd which is now at 3.11
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2019-I
Component: Systems Admin | Keywords:
I installed OSGeo7 with the lxd that came with Ubuntu 18.04 so that means
it's at LXD version 3.0.3, which at this point is "ancient".
Ubuntu policy is to stick this (only security updates for the life of it)
which means we'd be stuck at 3.0 for 5 years.
That said, the suggested recommendation for many software including LXD is
to use snap packages instead. Snap packages come in
stable
candidate
beta
edge
and they are generally set to upgrade automatically and allow downgrade to
previous working should something go wrong.
That said, I'd like to switch our LXD to the snap package version which is
at 3.11.
Aside from I think snap will give a better upgrade experience, I also want
the new pressing feature of lxd
LXD starting at 3.3 supports the proxy_protocol which both HAProxy and
NGINX support. This will allow our nginx proxy to properly pass along the
real ip address of the user making the request. This is important for
some apps such as wordpress and nextcloud which use tha info for blocking
access.
So before I bring any more containers on board, I'd like get this out of
the way.
I did a trial run on my own 18.04 server running lxd 3.0.3 that has about
10 containers one of whic is of comparable size to our nextcloud one (Our
biggest), and the upgrade was pretty fast. So I don't expect any issues.
I'll backup the containers first just in case.
For reference these are the steps I'll be taking to migrate
Based on this blog - https://blog.simos.info/how-to-migrate-lxd-from-deb-
ppa-package-to-snap-package/
apt install snapd
snap install lxd
lxd.migrate
The lxd.migrate process
1) shuts down the containers and the old lxd service
2) then moves them to the snapd version making any upgrade changes to the
containers needed
3) Then brings them back online
I'm also going to experiment with the nginx proxy thing on my test server
to confirm that all works as expected before I change the osgeo7 box.
If anybody has issue with the above plan, let me know.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2269>
OSGeo <https://osgeo.org/>
