#2278: Fix BackupWeb18a and review other failures
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2019-I
Component: Systems Admin | Keywords:
I started reviewing the bacula setup and querying the backup jobs.
Looks like Web18aBackup is broken and has been for sometime at least since
2018-09-29 which is the first listing I see for it
The download rsync job on that box appears to be working fine though I
can't access the download2.osgeo.org via web claimed in the docs.
I've started updating the wiki page with commands I find useful for
auditing bacula - https://wiki.osgeo.org/wiki/SAC:Bacula#Administration
At a glance the others seem to be working but haven't verified to see what
they are actually backing up
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2278>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
I think it might be because I blocked off most ports and it probably needs
to communicate on port 9102 is my understanding.
I've opened that port on web18a and manually triggerd a backup. It's
still recycling so too early to tell if that is the issue. Prior errors
were something of the form "couldn't connect to server"
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2278#comment:1>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
opening the 9102 port on web18a appears to have resolved the connection
issue and I now see files listed in the log.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2278#comment:2>
