#2280: Move all sites off of projects container
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2019-I
Component: Systems Admin | Keywords:
I checked projects.osgeo.osuosl.org
and confirmed that the following sites are still running on it.
featureserver.org might be defunct, by I think the others are still
actively used.
They are
spatialreference.org (sr.org.conf)
community-review.foss4g.org
featureserver.org
I don't have root access yet to see what other stuff might be running
here.
The spatialreference might be involved as it looks like it does a
proxypass to another server on this box.
featureserver since to run as a cgi, so might be equally complicated to
move off
community-review appears to be more or less static so can probably be
moved off easily
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2280>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by wildintellect):
spatialreference.org is a python based wsgi application, no need to move
the apache config. I helped move this once so I can assist. I think the
complication is that it might use a postgis database.
featureserver we can just try to mirror to static like the foss4g archive
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2280#comment:1>
Keywords: |
Comment (by neteler):
Replying to [comment:1 wildintellect]:
Please keep in mind that spatialreference.org is AFAIK totally outdated.
So a big related disclaimer would be good. Last update: 2013!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2280#comment:2>
Keywords: |
Comment (by warmerdam):
I'm seeing spatialreference.org as not-functioning -- I'm getting the
message "We are sorry, but requested page is currently unavailable.
Please try again later." at http://spatialreference.org.
GDAL uses spatialreference.org as a source of coordinate systems and
potentially a lot of folks around the work depend on this (including as it
happens the Planet Labs MODIS ingestors). I'd appreciate seeing
spatialreference.org continue to function.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2280#comment:3>
Keywords: |
I had no plans to retire it, I too agree that it still has use even if it
doesn't get active updates. The error you found is a new thing, let's open
a separate related ticket on that as it's not related to the moving which
is in progress not completed.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2280#comment:4>
Keywords: |
Comment (by rouault):
@wildintellect I might give a hand to help restoring spatialreference.org,
although I would need to have at least the starting point on which machine
this is installed (and the appropriate access permissions)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2280#comment:5>
Keywords: |
Comment (by robe):
Just an update. Instead of moving things off of projects, I'm migrating
projects to an lxd container using the lxd-psc tool.
Ran into some stumbling blocks mostly with fstab mounts, and the static
ip.
The container apache seems to work, but the nginx which is what sr.org
apparently runs under (proxied from the apache) is giving me a proxy
error.
Anyway hope to have it working before end of week.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2280#comment:6>
Keywords: |
Comment (by jef):
libdevmapper can be removed - it's apparently only used by grub.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2280#comment:7>
Keywords: |
I see that spatialreference.org works again now
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2280#comment:8>
Keywords: |
Comment (by robe):
Yah sorry about the downtime. I had shut down the databases before doing
a snapshot to get a clean snapshot of the VM. I haven't flipped to the
new yet as I'm still sorting thru some issues. I do see it is working in
the new container, but the Apache thing is a bit screwed up in that when I
asked for community-review.foss4g.org - I got spatialreference.org instead
(but it worked - I could navigate all the spatial ref sys). Once I have
that sorted out, I'll flip to the new server and then we can fiddle with
upgrading the debian OS later.
BTW I do have the ssh port open if anyone wants to check it out.
The **old-projects** container ssh is osgeo7.osgeo.osuosl.org -p 50025
Since it's a replica of the old, you should be able to get into it with
your ldap accounts.
I'm thinking since most of this stuff is obsolete, once it's working I'll
close off the ssh access, but you would still be able to ssh via the
download container to it.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2280#comment:9>
#2280: Move all sites off of projects.osgeo.osuosl.org and on to osgeo7 old-
projects container
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
I have made live on new container - spatialreference.org /
www.spatialreference.org
and community-review.org (not sure how to test this one as all I see is a
static page)
The spatialreference I took out of the apache enabled setup and just have
the nginx container proxy straight to the nginx 8092 port on the **old-
Change the DNS on Pairs and set letsencrypt on and force redirect to ssl.
My understanding with featureserver.org is that Chris was tired of it. I
haven't bothered trying to resuscitate it (its still pointing at old
server). wildintellect if you want to be my guest. I had issue getting
apache going as it seems to not match *: so only can serve one site and I
think it's got a bunch of other baggage behind it.
We could just have it run on another port I guess since it will be proxied
thru the nginx container anyway.
That said - unless anyone has any reason -- I think we can kill
projects.osgeo.osuosl.org.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2280#comment:10>
projects container
Keywords: |
Comment (by robe):
Oh I forgot to mention -- sr.org config had a bunch of aliases I couldn't
find in our pair account. Were these ever used?
spatial-reference.org
www.spatial-reference.org
www.spatialreferences.org
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2280#comment:11>
projects container
Type: task | Status: reopened
Keywords: |
Changes (by robe):
* status: closed => reopened
* resolution: fixed =>
Comment:
turns out community-review is still being used for foss4g2019 as I learned
from Paul.
The 2019 database was created after I moved over the VM.
I sent and email to Vasile and Volker and Paul that I restored the 2019
database on the new server and I shut down apache on the
projects.osgeo.osuosl.org to make sure I didn't miss anything.
I'll close this out once they confirm all is working.
I haven't remapped featureserver.org, but I guess I might as well do that
for closure.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2280#comment:12>
projects container
Keywords: |
Changes (by robe):
* status: reopened => closed
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2280#comment:13>
