#2281: Switch osgeo7 ssh to 2222 so 22 can be reserved for hosts
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2019-I
Component: Systems Admin | Keywords:
I'm planning to change osgeo7 host ssh port to 2222
that way if we really need it, we can use 22 for containers.
When I do I'll change the documentation accordingly.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2281>
OSGeo <https://osgeo.org/>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Done and I updated both the wiki or https://gitea.osgeo.org/sac/osgeo7
with these details
so now the only way to get into the host server is using the 2222 port and
via our admin account
ssh tech_dev@osgeo7.osuosl.org -p 2222
Note only those whose keys are installed have access to the host namely
wildintellect, strk, robe,martin
There is also access via the KVM, but that requires you have OpenVPN
connected to OSUOSL network (which robe and wildintellect have -- and in
theory strk and martin may have if they ever set themselves up)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2281#comment:1>
