#2285: Add additional ips to osgeo7
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2019-I
Component: Systems Admin | Keywords:
I think we are going to need more ips once we move everything over as for
example I had to open 22 for downloads because too many processes relying
on it being on 22.
I suspect we'll have similar issues with other things.
Right now the osgeo7 is configured for DHCP because I guess OSUOSL
reserved the ip for that. I'll confirm with them that it's okay for me to
make it static and add in the additional abandoned IPs we have from
servers gone.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2285>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
Spoke with OSUOSL they said fine and gave us list of our currently used
ips and said if we need more for migration, let them know.
Going to add the old base.osgeo.osuosl.org IP which is not currently in
use and probably never will again since it was a template for building VMS
on ganetti cluster.
I plan to do this in about 2 hrs from now.
There shouldn't be much down time, but I'd want to reboot the server to
make sure the ips stick, so will probably be down for 5-10 minutes.
Scream if this will be an issue for you.
At moment - production things running on it that will be impacted are
nextcloud.osgeo.org, community-review.foss4g.org, spatialreference.org,
dronie.osgeo.org
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2285#comment:1>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Done so now has static ips:
140.211.15.30 (the original we were given),140.211.15.57 (the old base
one)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2285#comment:2>
