#2291: http to https change
Reporter: jive | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
A couple things have stopped working due to a change:
- website: http://geotools.org (ends up showing files)
- maven repo http://download.osgeo.org/webdav/geotools/
- blogger:
https://geotoolsnews.blogspot.com/2019/03/geotools-203-released.html
(example of something using static http reference to http geotools.org)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2291>
OSGeo <https://osgeo.org/>
#2291: http to https change affecting geotools web resources
Component: Systems Admin | Resolution:
Keywords: |
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2291#comment:1>
Keywords: |
Comment (by robe):
I haven't been touching download.osgeo.org and haven't moved it yet.
I'll check in a bit to see what's up.
As I recall last time this happened was because the jenkins bot that
deploys the site put things in the wrong place. Is it possible that is
what is happening again?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2291#comment:2>
Type: task | Status: closed
Component: Systems Admin | Resolution: invalid
Keywords: |
Changes (by jive):
* status: new => closed
* resolution: => invalid
Comment:
Okay, checked with geotools team and it was the build server failing to
completely upload the website again:
> + scp web.zip geotools.org:/home/geotools/latest
> + cd ../../../target/user/html
> /tmp/jenkins4068331777872947770.sh: line 17: cd:
../../../target/user/html: No such file or directory
> Build step 'Execute shell' marked build as failure
> Sending e-mails to: geotools-devel@lists.sourceforge.net
> Finished: FAILURE
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2291#comment:3>
Keywords: |
Comment (by jive):
I am not sure if we want to keep this open as a transfer issue?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2291#comment:4>
Keywords: |
Comment (by robe):
No if any transfer issues occur we'll just create another ticket since
it's a different issue.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2291#comment:5>
