#2295: Replace ldaps STAR cert with letsencrypt or single cert
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: blocker | Milestone: Sysadmin Contract 2019-I
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
I tried tricking the system by sym-linking the letsencrypt cert files to
the old names.
That did not work on the old-secure container so I didn't bother with the
actual secure.
Sooo I've moved on to plan D - which was the eventual direction of
scraping the old ldap and replacing with a new LDAP.
I have a container on osgeo7 called new-secure - which has 636 open to
OSUOSL domain and LXD subdomain. I'm going to transcribe the rest of the
whitelists to it once I've troubleshooted some things and tested on some
other things.
The new ldap is running Debian 9 and using letsencrypt wildcard cert.
Took a lot of fumbling to figure out how to get this working. I also
restored the old ldap users database, but not the config. config I
rebuilt from scratch.
I tested accessing it from web18a.osuosl.org VM (which is fairly new), the
nextcloud container (swapping out old ldap with new ldap) and both worked:
Here is a test
ldapsearch -x "uid=robe" -b "dc=osgeo,dc=org" -H ldaps://ldap2.osgeo.org
Which shows my details.
However this did not work on current secure or osgeo6 (I assume it will be
an issue with all our old servers) -- I think just missing an intermediary
cert for le, because when I run:
ldapsearch -d1 -x "uid=robe" -b "dc=osgeo,dc=org" -H
ldaps://ldap2.osgeo.org #d1 for debug details
on secure gives this:
TLS: peer cert untrusted or revoked (0x42)
TLS: can't connect: (unknown error code).
ldap_err2string
ldap_sasl_bind(SIMPLE): Can't contact LDAP server (-1)
If I swap out the letsencrypt on ldap2 with the old ssl, secure can query
it. So it's definitely the cert and not any firewall issue.
I was disappointed this did not work out of the box on osgeo6 and gave the
same notice
ldap_connect_to_host: Trying 140.211.15.57:636
ldap_pvt_connect: fd: 4 tm: -1 async: 0
attempting to connect:
connect success
ldap_err2string
But it could be we've been copying the cert authorities across all the
servers and they are just missing the newer ones.
Anyway hoping it's simple as just copying newer certs as this describes:
https://serverfault.com/questions/579131/some-systems-cannot-connect-to-
ldap-via-ldaps-but-others-can-is-it-the-wildcar/579148
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2295#comment:3>
OSGeo <https://osgeo.org/>
