#2296: download.osgeo.org certificate not recognized by curl / wget
Reporter: rouault | Owner: sac@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
Since a few hours ago (April 28 2019), I get errors from curl and wget
when downloading from https://download.osgeo.org. This is on Ubuntu 16.04
(and also true from Travis-CI workers)
$ curl https://download.osgeo.org/proj/proj-6.0.0RC4.tar.gz
curl: (60) server certificate verification failed. CAfile: /etc/ssl/certs
/ca-certificates.crt CRLfile: none
More details here: http://curl.haxx.se/docs/sslcerts.html
curl performs SSL certificate verification by default, using a "bundle"
of Certificate Authority (CA) public keys (CA certs). If the default
bundle file isn't adequate, you can specify an alternate file
using the --cacert option.
If this HTTPS server uses a certificate signed by a CA represented in
the bundle, the certificate verification probably failed due to a
problem with the certificate (it might be expired, or the name might
not match the domain name in the URL).
If you'd like to turn off curl's verification of the certificate, use
the -k (or --insecure) option.
$ wget https://download.osgeo.org/proj/proj-6.0.0RC4.tar.gz
--2019-04-28 12:25:26--
Resolving download.osgeo.org (download.osgeo.org)... 140.211.15.132
Connecting to download.osgeo.org
(download.osgeo.org)|140.211.15.132|:443... connected.
ERROR: cannot verify download.osgeo.org's certificate, issued by
'CN=Let\'s Encrypt Authority X3,O=Let\'s Encrypt,C=US':
Unable to locally verify the issuer's authority.
To connect to download.osgeo.org insecurely, use `--no-check-certificate'.
In Firefox 66, this works
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2296>
OSGeo <https://osgeo.org/>
