#2297: Drone (agent?) is failing to reach docker
Reporter: strk | Owner: robe
Type: task | Status: assigned
Priority: normal | Milestone: Sysadmin Contract 2019-I
Component: Systems Admin | Keywords:
See https://dronie.osgeo.org/postgis/postgis/240
Error message is:
pg-9.5: Cannot connect to the Docker daemon at
unix:///var/run/docker.sock. Is the docker daemon running?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2297>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by strk):
Odd, one of the 3 matrix jobs did work in cloning (the pg10 one), in that
build.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2297#comment:1>
Keywords: |
Comment (by robe):
As mentioned on irc. This might have to do with my upgrade to 1.0.
The job that is succeeding is the drone that runs directly on dronie-
server. The other ones failing are run on ianna and debbie-docker.
It's hard to say if upgrade is the issue as lots of things were happening
at same time.
The reason why a matrix job fails is each job task of a matrix is being
passed to a different agent. For ow I've shut ffo the drones on ianna and
debbie-docker and restarted the failing job to see if that fixes the
issue.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2297#comment:2>
Keywords: |
Comment (by strk):
Shutting down ianna and debbie-docker seemed to have fixed the issue
for now. Let's keep this open until we put those agents back online
though, as builds are slower now...
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2297#comment:3>
Keywords: |
Comment (by strk):
I'm taking it back, the problem is still not fixed.
See https://dronie.osgeo.org/postgis/postgis/254/3/1
Any other agent connected to the server ?
Can you check the logs to tell, Regina ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2297#comment:4>
Keywords: |
Comment (by strk):
{{{ docker logs }}} doesn't show any detail about which agents are
connected from which IP addresses. The only visible information in the
logs is the error of a {{{ runner }}} with identifier {{{
"machine":"399d4d53c8f9" }}} that starts execution and fails.
I don't know why there's no trace about any other machines.
Logs of the agent docker contain info about both successful and failing
build, but w/out details of the failure, and no trace of the {{{
399d4d53c8f9 }}} identifier.
Where are the server and the agents configured ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2297#comment:5>
Keywords: |
Comment (by robe):
Details here - https://git.osgeo.org/gitea/sac/osgeo7/wiki/Dronie-Server-
container
I did turn off the others, so does seem to be some sort of dronie server
agent issue.
I suppose I can revert back to before I upgraded to 1.0 version (last was
rc5).
or I could just wipe out the database.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2297#comment:6>
Keywords: |
Comment (by robe):
Forgot to say not sure why it's even trying to reach the other agents when
I shut them down.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2297#comment:7>
Keywords: |
Comment (by strk):
Regina can you make me an administrator of the drone-1.0 server ? Chances
are there's some admin menu. How do you tell it is trying to access other
agents ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2297#comment:8>
Keywords: |
Comment (by strk):
The instructions on https://git.osgeo.org/gitea/sac/osgeo7/wiki/Dronie-
Server-container seem to say that the server and the agent are started via
{{{ lxc }}} but while on osgeo7 machine I see them running in docker {{{
docker ps }}} -- what's the deal ? Is there an overlap between {{{ lxc }}}
and {{{ docker }}} ? Or are we running two services in parallel ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2297#comment:9>
Keywords: |
Comment (by strk):
This is an interesting info to add to the wiki:
https://github.com/drone/drone/issues/1496
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2297#comment:10>
Keywords: |
Comment (by strk):
Thread on Drone support forum addressing this error:
https://discourse.drone.io/t/cannot-connect-to-the-docker-daemon-at-unix-
var-run-docker-sock-is-the-docker-daemon-running/4071
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2297#comment:11>
Keywords: |
Comment (by strk):
Regina: you're missing DRONE_AGENTS_ENABLED=true to the server startup
script
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2297#comment:12>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by strk):
* status: assigned => closed
* resolution: => fixed
Comment:
Fix confirmed (was a missing DRONE_AGENTS_ENABLED variable)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2297#comment:13>
