#2298: Account Creation Error
Reporter: wildintellect | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
Probably related to the work on secure and migration of cert.
Although it could be accented characters, we still don't support those
right? Let me know if you need the contact info for the user having the
issue.
Traceback (most recent call last): File
"/usr/lib/cgi-bin/ldap_create_user.py", line 248, in
ldap_add(uid,cn,sn,mail,password)
File "/usr/lib/cgi-bin/ldap_create_user.py", line 133, in ldap_add
l.simple_bind_s(who,cred) INVALID_CREDENTIALS: {'desc': 'Invalid
credentials'}
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2298>
OSGeo <https://osgeo.org/>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
This should be fixed now. Had to change the RootDN
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2298#comment:1>
Keywords: |
Comment (by strk):
INVALID CREDENTIALS sounds more about the credentials used
to obtain authorization to create accounts...
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2298#comment:2>
Keywords: |
Comment (by robe):
It's both. When LDAP creates the root account it defaults the name to
cn=admin,dc=osgeo,dc=org. I had created the config on new ldap from
scratch because even with the Manager account I couldn't make
configuration changes (like changing the SSL cert).
Anyway when I created the new LDAP I did set the password to the same as
the old, but that wasn't enough because the RootDN was
I had to change this RootDN to cn=Manager,dc=osgeo,dc=org because that's
what the creation scripts were using.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2298#comment:3>
