#2312: Update key for deploying docs to geotools.org
Reporter: tbarsballe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords: geotools
The Jenkins CI server for the GeoTools project (build.geoserver.org)
recently experienced a security breach.
As such, we have rebuilt the server and regenerated all keys. One of these
was the key used to upload documentation to docs.geotools.org
As per #1931, OSGeo controls the geotools.org domain.
We need someone to remove the previous key and add the new one we have
generated.
I am not quite sure what the security configuration looks like on
docs.geotools.org; besides the publickey, do you need anything else from
us, or is there any other configuration required on our end?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2312>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: geotools |
Comment (by robe):
jody can you send me the keys that need replacing. on the geotools home
folder osge osgeo6 (where geotools is installed) I see both public and
private keys. Not sure what the private key is for.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2312#comment:1>
Comment (by robe):
FYI in the authorized_keys I see a key for jenkins@build-
slave-01.geoserver.org
if you aren't using osgeo6 to further deploy to any other server, I
suspect we can delete the private key
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2312#comment:2>
Comment (by robe):
tbarsballe you can send me the keys via lr@pcorp.us and I'll take care of
it.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2312#comment:3>
Comment (by robe):
Got the public key from tbarsballe and removed the old one and installed
this new one.
Also got rid of the private key because Torben said to his knowledge it is
not used
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2312#comment:4>
Type: task | Status: closed
Priority: normal | Milestone: Sysadmin Contract 2019-I
Component: Systems Admin | Resolution: fixed
Changes (by robe):
* status: new => closed
* resolution: => fixed
* milestone: => Sysadmin Contract 2019-I
Comment:
I'm closing this out - feel free to reopen if there is an issue
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2312#comment:5>
