#2314: osgeo3 and osgeo4 power supplies need replacement
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: blocker | Milestone: Unplanned
Component: Systems Admin | Keywords:
Lance wrote today.
His notes:
I was in the data center yesterday and noticed that both osgeo3 and osgeo4
each have a failed PSU (power supply unit) which should be replaced before
moving forward on this. Thankfully, these are fairly cheap and cost around
$35 [1] [2].
If you want to look elsewhere, just look for part number YFG1C which
should be the 870W PSU.
Sorry I didn't notice that sooner.
[1] https://www.amazon.com/YFG1C-Dell-Power-Supply-
PowerEdge-x/dp/B00456W6A2
[2] https://www.newegg.com/p/1HU-005J-00549
Alex, can you take care of this as soon as you can?
Regina
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2314>
OSGeo <https://osgeo.org/>
Reporter: robe | Owner: wildintellect
Component: Systems Admin | Resolution:
Keywords: |
Changes (by robe):
* owner: sac@… => wildintellect
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2314#comment:1>
Keywords: |
Comment (by wildintellect):
Parts ordered. Should arrive Monday July 1, $776
* 2x YFG1C Dell 870W Power Supply
https://www.amazon.com/dp/B00456W6A2/ref=cm_sw_r_tw_dp_U_x_voaaDbABVTDES
* 6x Seagate Exos 7E2 2TB Internal Hard Drive HDD – 3.5 Inch 6Gb/s 7200
RPM 128MB SATA
https://www.amazon.com/dp/B07D98C9XB/ref=cm_sw_r_tw_dp_U_x_KYaaDbHS3TGFS
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2314#comment:2>
Keywords: |
Comment (by robe):
Note that osgeo4 is all setup with the new power supply and drives. I
have installed LXD on it using 4 of the 6 disks for total storage of 3.62
TB (essentially a RAID 10 config).
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2314#comment:3>
Keywords: |
Comment (by robe):
It appears we've used all the disks we purchages on osgeo4.
I think originally we were going to split between the two but osgeo4 could
handle all 6 so we figured why the heck not.
So that leaves us with no disks to give to osgeo3.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2314#comment:4>
Keywords: |
I don't recall expecting to put any of the new drives into osgeo3, just
the PSU. Given the age, we could put a drive refresh into the new budget
since we plan to keep the machine for another cycle.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2314#comment:5>
#2314: osgeo4 power supplies need replacement
Keywords: |
Comment (by robe):
It appears that the power supplies and drives we got were all used for
osgeo4.
So closing this ticket out and will create a new one for osgeo3
https://lists.osgeo.org/pipermail/sac/2019-December/011746.html
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2314#comment:6>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
closing this out as we have a separate ticket for osgeo3, and osgeo4 is
all set as far as hardware needs.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2314#comment:7>
