#2317: Failed to deploy artifacts dav:http://download.osgeo.org/webdav/geotools/
Reporter: jive | Owner: sac@…
Type: defect | Status: new
Priority: major | Milestone:
Component: Systems Admin | Keywords:
This is a possible follow up to:
* https://trac.osgeo.org/osgeo/ticket/2291
* https://trac.osgeo.org/osgeo/ticket/2183
And may just consist of updating my permissions with a little help.
I am performing a manual deploy of geotools to the OSGeo repository as our
build server has been unavailable for about a month. While I am able to
deploy to repo.boundlessgeo.com (so I know my script is working) deploying
to the osgeo repository is failing with the following error:
> Failed to deploy artifacts: Could not find artifact
org.geotools:geotools:pom:20.4 in osgeo
(dav:http://download.osgeo.org/webdav/geotools/)
My .m2/settings.xml contains my credentials which I updated on May 10th as
per #2291. Has anything changed or has additional security measures been
put in place on this resource?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2317>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by jive):
I am marking this as urgent (higher than normal) priority since it is
holding up a release
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2317#comment:1>
Keywords: |
Comment (by jive):
It could be all the keys have been reset as per
https://trac.osgeo.org/osgeo/ticket/2312
Ideally we would like committers to be able to deploy and the build box be
able to deploy.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2317#comment:2>
Keywords: |
Comment (by robe):
Jive,
I did remove a private key because I was told it was not in use. We might
need to reput that back in.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2317#comment:3>
Keywords: |
Comment (by robe):
oh actually just realized that would have nothing to do with that if you
are going thru webdav.
We had changed the keys remember and I sent you the new password. But we
tested right after together and it was working. Did it suddenly stop
working.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2317#comment:4>
Keywords: |
Comment (by robe):
now I remember what we decided -- the deploy is not to webdav
It should be to
http://download.osgeo.org/upload/geotools/
Remember we couldn't change webdav because too many public sites are using
it.
And for some reason webdav couldn't get to work for both. Though now I
htink it was just a misconfiguration on my part so we could go back to
using webdav. webdav being called webdav and not being really webdav is
kinda confusing.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2317#comment:5>
Type: defect | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
tbarsballe was able to use the geotools webdav account I sent to upload to
the upload/geotools.
I had to increase limit to 100MB since 1MB is the default and some items
could not be pushed.
Change committed at:
https://git.osgeo.org/gitea/sac/download-
config/commit/2bb21ac8958c7ada66fdbfc183f90fb3a8e9b78d
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2317#comment:6>
Keywords: |
Comment (by aaime):
I'm trying to upload a file to dav using my OsGeo LDAP account, but keep
on getting a 401... do I need a different account?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2317#comment:7>
Type: defect | Status: reopened
Keywords: |
Changes (by wildintellect):
* status: closed => reopened
* resolution: fixed =>
Comment:
There are additional users that need the same permissions. We should
probably clarify what the fix is and document it somewhere the Geotools
community shares information.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2317#comment:8>
Keywords: |
Comment (by robe):
There were two approaches. One using a local webdav account and one using
sftp like everyone else.
Can you talk to tbarsballe about this. I think he settled on using sftp
with a key he provided me. I don't know the details of what was done on
the java side for geoserver/geotools sides. Also not sure where the best
place is to document this.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2317#comment:9>
Keywords: |
Comment (by robe):
sent Andrea the webdav account info and cc'd wildintellect, jive and
tbarsballe
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2317#comment:10>
Keywords: |
Changes (by robe):
* status: reopened => closed
Comment:
Andrea said the credentials worked for him so closing this out. I'll add
the password info to secure.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2317#comment:11>
