#2327: Lost access to upload.osgeo.org
Reporter: jng | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
I caught wind of this message on the SAC mailing list:
http://osgeo-org.1560.x6.nabble.com/Download-server-has-moved-and-
requires-SSH-key-access-to-upload-td5404626.html
I am one of those users who used password access, which I gather is now
blocked now.
What is required for SSH key access so I can upload MapGuide/FDO artifacts
again?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2327>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by wildintellect):
Please provide us with your public key (usually something like id_rsa.pub)
so we can load it onto the server.
If you're not sure how to make an ssh key,
https://www.linode.com/docs/security/authentication/use-public-key-
authentication-with-ssh/#generate-a-key-pair (Also works on Win 10 now)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2327#comment:1>
Keywords: |
Changes (by jng):
* Attachment "id_rsa.pub" added.
My generated ssh key
Keywords: |
Comment (by jng):
Attached my public ssh key (generated with PuTTYgen)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2327#comment:2>
Keywords: |
Comment (by jng):
Any update? Anything wrong with the key I posted?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2327#comment:3>
Keywords: |
Comment (by strk):
The key has indeed a weird format, but I installed it removing newlines
and header/footer, see if that helps please
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2327#comment:4>
Keywords: |
Changes (by jng):
* Attachment "id_rsa_2.pub" added.
My generated ssh key (authorized_keys format)
Keywords: |
Comment (by jng):
I can't connect with WinSCP or PuTTY with my private key. I get:
No supported authentication methods available (server sent public key)
Based on this (https://askubuntu.com/questions/204400/ssh-public-key-no-
supported-authentication-methods-available-server-sent-publ), I think I
may have given you the public key in the wrong format. I've added
`id_rsa_2.pub`, which I think is the expected format for `authorized_keys`
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2327#comment:5>
Keywords: |
Comment (by strk):
Installed, please try again
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2327#comment:6>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by jng):
* status: new => closed
* resolution: => fixed
Comment:
Yep, that did the trick. I can upload artifacts again. Thank you for your
assistance.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2327#comment:7>
