#2331: migrate coc@osgeo.org private email list to alias
Reporter: jive | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
Follow on to #2227 - when sending an email to coc@osgeo.org you get a very
rude response about attempting to email a private list - indeed it looks
like an error and like service is broken.
Can this list be changed to an alias similar to board-priv@osgeo.org?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2331>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by Delawen):
It should be an email alias received only by the members of the CoC. I
guess the CoC members can't add/remove members without going through SAC?
(Trying to lower your tasks).
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2331#comment:1>
Keywords: |
Comment (by jive):
I would like SAC to control the email addressed forwarded from the alias.
Of course if we could configure mailman not to send the "must be a member
of the email list to post" automated response that would get rid of the
problem and be even easier.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2331#comment:2>
#2331: coc@osgeo.org contact email should not issue automated "message to private
email list" response
Keywords: |
Comment (by jive):
This is quite the challenge, I see #2227 separated out the discussion list
from the email contact point which is good...
I should rename this issue so it is clear the problem is the automated
respsponse (how to fix is open to suggestions).
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2331#comment:3>
Keywords: |
Comment (by wildintellect):
We can change the message to explain that the submission has been received
and will be reviewed.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2331#comment:4>
Keywords: |
Comment (by jive):
That actually sounds perfect, thank you!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2331#comment:5>
Reporter: jive | Owner: jsanz
Component: Mailing Lists | Resolution:
Keywords: |
Changes (by wildintellect):
* owner: sac@… => jsanz
* component: Systems Admin => Mailing Lists
Comment:
Someone please draft the text you want people to receive, post it here,
and we'll put it into the list config. Thanks.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2331#comment:6>
Type: task | Status: closed
Component: Mails & Mailing Lists | Resolution: invalid
Keywords: |
Changes (by cvvergara):
* status: new => closed
* resolution: => invalid
Comment:
coc was changed to conduct-report
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2331#comment:7>
