#2332: OSGeoLive mailing list asks for confirmation for every ticket update from
trac
Reporter: kalxas | Owner: sac@…
Type: task | Status: new
Priority: major | Milestone:
Component: Systems Admin | Keywords: osgeolive trac
When we open a new ticket or update an old one, we add
osgeolive@lists.osgeo.org in CC.
Mailman asks for confirmation every time, even if we have whitelisted that
e-mail address...
Is there a way to automatically subscribe trac_osgeolive@osgeo.org to the
osgeolive mailing list?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2332>
OSGeo <https://osgeo.org/>
trac
Type: defect | Status: new
Component: Systems Admin | Resolution:
Keywords: osgeolive trac |
Changes (by kalxas):
* type: task => defect
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2332#comment:1>
trac
Comment (by neteler):
Replying to [ticket:2332 kalxas]:
Are you sure that this is the right sender address?
In grass-dev, we have added under "List of non-member addresses whose
postings should be automatically accepted." this address:
trac@osgeo.org
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2332#comment:2>
trac
Comment (by kalxas):
Thanks Markus,
I added the proposed e-mail but still, the messages do not go through.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2332#comment:3>
trac
I just see that in addition:
Privacy options > Recipient filters > Alias names (regexps) which qualify
as explicit to or cc destination names for this list. > trac@osgeo.org
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2332#comment:4>
trac
Added and still does not work ![:frowning: :frowning:](/images/emoji/twitter/frowning.png?v=12)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2332#comment:5>
trac
I checked and see differences in the trac config:
/var/www/trac/osgeo/conf/trac.ini vs /var/www/trac/osgeo/conf/trac.ini
[notification]
@@ -7,10 +7,10 @@
smtp_always_cc =
smtp_default_domain =
smtp_enabled = true
-smtp_from = trac_osgeo@osgeo.org
+smtp_from = trac@osgeo.org
smtp_password =
smtp_port = 25
-smtp_replyto = warmerdam@pobox.com
+smtp_replyto = grass-dev@lists.osgeo.org
smtp_server = localhost
smtp_subject_prefix = __default__
smtp_user =
So I suppose that you need to adapt the two smtp_XXX settings as well.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2332#comment:6>
trac
I do not have access to that file, can someone please apply this change?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2332#comment:7>
trac
I hesitate to change it, perhaps you (also) whitelist
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2332#comment:8>
trac
did that, no change.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2332#comment:9>
trac
Comment (by robe):
Is this still an issue?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2332#comment:10>
trac
Type: defect | Status: closed
Component: Systems Admin | Resolution: wontfix
Changes (by robe):
* status: new => closed
* resolution: => wontfix
Comment:
since no response assume this is no longer an issue.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2332#comment:11>
