#2345: Grant admin access to Drone server to strk
Reporter: strk | Owner: robe
Type: task | Status: assigned
Priority: normal | Milestone: Sysadmin Contract 2019-II
Component: Systems Admin | Keywords:
According to https://docs.drone.io/administration/user/admins/ an admin
can grant admin privs to other users via the WEB ui.
This ticket is to request being given admin access to dronie.osgeo.org
BTW: should "Sysadmin Contract 2019-I" be closed as a milestone ?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2345>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
okay closed that milestone. I suspect I set this up wrong since I don't
see any admin section when I log in.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2345#comment:1>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by strk):
* status: assigned => closed
* resolution: => fixed
Comment:
I've granted me admin via sql directly. Cannot tell if that worked because
the GUI is the same, but as Regina mentioned the same thing, I'm going to
close this as done, and we'll need to figure out the GUI issue separately.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2345#comment:2>
