#2351: Lime Survey instance
Reporter: jgrocha | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
The Lime Survey instance is down.
The link is: https://limesurvey.osgeo.org/
Can it be back online to support the next election process?
Jorge Gustavo
(from the CRO team)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2351>
OSGeo <https://osgeo.org/>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Sorry for some reason the service was stopped. Wasn't intentional.
I just started it back up. Let me know if you run into any issues.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2351#comment:1>
Keywords: |
Comment (by jgrocha):
Thank you so much for the prompt answer!
The Lime survey is running, but there might be a problem connection to
LDAP.
Can you please go to the login page and test the login?
https://limesurvey.osgeo.org/index.php?r=admin/authentication/sa/login
The reported error is just: "Protocol error"
Thanks!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2351#comment:2>
Type: task | Status: reopened
Keywords: |
Changes (by jgrocha):
* status: closed => reopened
* resolution: fixed =>
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2351#comment:3>
Keywords: |
Comment (by robe):
Looking into this now. I was hoping it was as simple as I forgot to
whitelist the funtoo server when I moved ldap, but ldap queries I do seem
okay.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2351#comment:4>
Keywords: |
Changes (by robe):
* status: reopened => closed
Comment:
Try now. I had to up the LDAP version from LDAPv2 to LDAPv3. Guess
caused by change of the secure rebuild which has a newer LDAP.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2351#comment:5>
Keywords: |
Comment (by robe):
The LDAP config I'm talking about is in Limesurvey -> Configuration ->
Settings -> Plugin Manager -> LDAP.
I had also change port to 636 (says default is 389, but I assume that is
just for non-secure ldap) but put it in there just in case.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2351#comment:6>
Keywords: |
Thanks, Regina
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2351#comment:7>
