#2355: Move www.osgeo.org to osgeo7 (wordpress container)
Reporter: robe | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone: Sysadmin Contract 2019-II
Component: Systems Admin | Keywords:
www.osgeo.org is currently hosted on web18a (which is a VM provided by
OSUOSL). This was done as a temporary solution until we had enough server
to run it ourselves.
I think now is the time. Right now I have an image of web18a that is
several months old running on osgeo4 as wordpress-dev. Preliminary tests
I've done show that the wordpress-dev is faster than production. Rather
than figuring out what's wrong with web18a, I think its time to just move
it and then if speed is still an issue troubleshooting then.
That said I'll make another image of it this week on osgeo7 and repeat all
the steps I did for osgeo4.
Note this move also means redirect for www.gdal.org and also moving over
foss4g2018 which was also housed on web18a.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2355>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by robe):
I have moved over 2018.foss4g.org and www.osgeo.org to osgeo7.
I'll close this out once I've moved the proxy for www.gdal.org to osgeo7
and shut down the services on web18a.
I figure I'll give it a day or 2 for dns to propagate before I shut down
the old site. In mean time people should refrain from making changes to
the site.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2355#comment:1>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Moved proxy for www.gdal.org to osgeo7 and shutdown the apache service on
web18a. I'll let it sit for a week to make sure nothing missed and then
tell osuosl to shutdown web18a VM.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2355#comment:2>
