#2356: 2020.foss4g.org A record
Reporter: pramsey | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
Can we have an 'A' record pointing to 184.168.131.241 please?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2356>
OSGeo <https://osgeo.org/>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by wildintellect):
* status: new => closed
* resolution: => fixed
Comment:
Removed the CNAME to www.foss4g2020.com and add A record as requested.
Why are we not pointing directly at 2020foss4g.ca servers? The redirect
service being used seems fragile, at least on my browser.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2356#comment:1>
Type: task | Status: reopened
Keywords: |
* status: closed => reopened
* resolution: fixed =>
Comment:
Not working, I think something is wrong with the redirect on your side.
Looks like maybe you're using Cloudflare or AWS, and something might need
to be changed on that end.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2356#comment:2>
Keywords: |
Comment (by wildintellect):
The IP given was to some sort of URL shortener/redirector and didn't work.
After getting the IP for the true site:
$ dig +short 2020foss4g.ca
52.60.138.213
35.183.196.77
I pointed to the first IP returned. Depending on the hosting service this
may not be reliable (if IPs can shift). So let me know if this should be
different. Otherwise the DNS works now.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2356#comment:3>
Keywords: |
Comment (by pramsey):
Can we try a CNAME to 2020foss4g.ca? Maybe that will be better?
2020foss4g.com is a HTTP redirect, but 2020foss4g.ca appears to be an
actual server. Unfortunately the hosting co seems to migrate it around to
different IPs on their own schedule.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2356#comment:4>
Keywords: |
Ok swapped to CNAME, should be working in an hour. Let us know if it's
not.
PS: After it's working please make sure to get an https cert working.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2356#comment:5>
Keywords: |
Changes (by robe):
* status: reopened => closed
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2356#comment:6>
