#2361: Create ML for Lizmap project
Reporter: rldhont | Owner: jsanz
Type: task | Status: new
Priority: normal | Milestone:
Component: Mailing Lists | Keywords:
Dear SAC,
On behalf of Lizmap developers and contributors, I would like to kindly
ask you to set up a mailing list for Lizmap project.
Lizmap is an open source application based on QGIS and QGIS Server to
easily configure and publish web map applications.
* https://github.com/3liz/lizmap-web-client/
* https://github.com/3liz/lizmap-plugin/
* https://github.com/3liz/lizmap-rfc/
* https://www.lizmap.com/en
Mailing list config:
* name: Lizmap
* admins: rldhont@gmail.com, kimaidou@gmail.com
Thank you for setting it up!
René-Luc
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2361>
OSGeo <https://osgeo.org/>
Component: Mailing Lists | Resolution:
Keywords: |
Comment (by rldhont):
Can you add giovanni.manghi@gmail.com and cavallini@faunalia.it as admins
Thanks.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2361#comment:1>
Type: task | Status: closed
Component: Mailing Lists | Resolution: fixed
Keywords: |
Changes (by jsanz):
* status: new => closed
* resolution: => fixed
Comment:
List and archived created:
- https://lists.osgeo.org/mailman/listinfo/lizmap
- http://osgeo-org.1560.x6.nabble.com/Lizmap-f5416555.html
I will send the list details to all four admins separately.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2361#comment:2>
Keywords: |
Thanks
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2361#comment:3>
