#2365: Can't SSH to lists.osgeo.org
Reporter: jsanz | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
Trying to address #2364 I see I can't log into `lists.osgeo.org` anymore.
I'm on a new computer, and I've created a new public key just to be sure.
Leaving below the output for the connection attempt.
Let me know if you need further details.
Thanks!!
~ ssh -v -i ~/.ssh/id_rsa_osgeo jsanz@lists.osgeo.org
OpenSSH_7.9p1 Ubuntu-10, OpenSSL 1.1.1b 26 Feb 2019
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug1: Connecting to lists.osgeo.org [140.211.15.3] port 22.
debug1: Connection established.
debug1: identity file /home/j/.ssh/id_rsa_osgeo type 0
debug1: identity file /home/j/.ssh/id_rsa_osgeo-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_7.9p1 Ubuntu-10
debug1: Remote protocol version 2.0, remote software version OpenSSH_6.7p1
Debian-5+deb8u8
debug1: match: OpenSSH_6.7p1 Debian-5+deb8u8 pat OpenSSH* compat
0x04000000
debug1: Authenticating to lists.osgeo.org:22 as 'jsanz'
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: algorithm: curve25519-sha256@libssh.org
debug1: kex: host key algorithm: ecdsa-sha2-nistp256
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC:
<implicit> compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC:
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: ecdsa-sha2-nistp256
SHA256:4RfKgSNW5ItzrXsjtiMzZ8YhmnphhsDIpA/wi/9xLZM
debug1: Host 'lists.osgeo.org' is known and matches the ECDSA host key.
debug1: Found key in /home/j/.ssh/known_hosts:5
debug1: rekey after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: Will attempt key: jorge.sanz@elastic.co RSA
SHA256:WdqOd3r12XRo7z/SD+LJrb6qgp9lcg/jKHW1xHZGcec agent
debug1: Will attempt key: /home/j/.ssh/id_rsa_osgeo RSA
SHA256:Gn45tCDj3SxzEUVKpurPIn9fITBpGTblrh5QeGHsjxY explicit
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey
debug1: Next authentication method: publickey
debug1: Offering public key: jorge.sanz@elastic.co RSA
debug1: Offering public key: /home/j/.ssh/id_rsa_osgeo RSA
debug1: No more authentication methods to try.
jsanz@lists.osgeo.org: Permission denied (publickey).
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2365>
OSGeo <https://osgeo.org/>
