#2368: Making Oskari Jetty-bundle available through download.osgeo.org
Reporter: tmiosmauli | Owner: sac@…
Type: task | Status: new
Priority: normal | Milestone:
Component: Systems Admin | Keywords:
Hi!
We'd like to offer Oskari (www.oskari.org - currently incubating to become
an OSGeo project) through the download.osgeo.org-server. Especially we'd
like to offer the version which has Jetty bundled. It's in the form of a
zip file which is updated every time we make a new release. Do you think
it could be possible and how should we proceed with this?
Kind regards,
Timo Aarnio
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2368>
OSGeo <https://osgeo.org/>
Component: Systems Admin | Resolution:
Keywords: |
Comment (by wildintellect):
You will need to provide a public key for use with ssh (for each user that
will need access, they also need to have an osgeo account like you do).
Alex
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2368#comment:1>
Keywords: |
Comment (by tmiosmauli):
We're using jenkins, so this should do if I'm not mistaken.
ssh-rsa
AAAAB3NzaC1yc2EAAAADAQABAAABAQC6rmuai+RFdLOopd2LJDE61FQa8rTMkJDOID6EaeZABkKg8KtGLBbidC0vopSgtUQ0Xzxkk+rj6uw4XPXqWBf/phailR3o4auvmIDBRcdC/xpNIBZJfHsDvzoQw9IYVUS7sEDZ182PUWMZocBysBoUtzOuUGtaIZkF1gsm07QPg0+IiHxwc3pGIr9N5kOsS+dbzno+2M3gz1IAHDs5NZjneuYtU00EiOYLOhnXwPnDTOlaAcZDNCBoy/Rd0FMoJb9u4ZjTQbXCqekuRfPxSwA4kpM59rRuuSBKuCoC6px8/DwuNQJSpvKTp1/8cx+9kJnbFN3oL6po1uTqFcvSVcVB
jenkins@oskarici01.nls.fi
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2368#comment:2>
Type: task | Status: closed
Component: Systems Admin | Resolution: fixed
Keywords: |
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
tmiosmauli -- I had to add you to the shell group as well since you
weren't in there.
I installed the above public key in your home so you should be able to
ssh tmiosmauli@download.osgeo.org and also sftp with that account and
key.
Feel free to open this if you still have issues.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2368#comment:3>
Type: task | Status: reopened
Keywords: |
Changes (by tmiosmauli):
* status: closed => reopened
* resolution: fixed =>
Comment:
Hi!
We FINALLY got the firewall configuration from our IT-services so that we
can connect, but it seems something is still blocking us from accessing
download.osgeo.org with SSH. Do we need to provide you the IP-address
we're connecting from or should it be open accessible already now?
Thank you for your help!
Kind regards,
Timo
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2368#comment:4>
Keywords: |
Comment (by robe):
No ip blocks on download.osgeo.org. However only allows ssh key access.
Are you using the key you provided me to ssh?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2368#comment:5>
Keywords: |
Comment (by robe):
Timo,
Let me know if you are still having issue and I'll check on your account.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2368#comment:6>
Keywords: |
Comment (by robe):
Forgot to mention we also how a new server repo.osgeo.org using Nexus repo
software that can house maven, apt, docker registries -
https://repo.osgeo.org/
Let me know if you are interested in that as well.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2368#comment:7>
Keywords: |
Comment (by robe):
Are you still having issues here Timo?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2368#comment:8>
Keywords: |
SSH'ing works now, thank you!
We might be interested also in the repo.osgeo.org server at some point in
time, but given how long it takes for our IT to get a simple hole poked in
the firewall it's best if we don't get too ambitious ![:wink: :wink:](/images/emoji/twitter/wink.png?v=12)
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2368#comment:9>
Keywords: |
Changes (by robe):
* status: reopened => closed
Comment:
Thanks for the confirmation Timo. Feel free to put in another ticket for
the repo access.
You should be able to log in already to it by the way
with your osgeo account.
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2368#comment:10>
Keywords: |
Comment:
Hi!
It seems that an administrator should create a download-folder for us,
could someone help with that? The wiki-page:
https://wiki.osgeo.org/wiki/Download_Server says "It is intended that each
interested project should have a directory under /osgeo/download with
appropriate permissions so a project member can manage the subdirectories
and files. Scp, or sftp can be used to bring files onto the server.
Someone from each project will need their LDAP OSGeo Userid shell enabled,
for ssh/scp access.
Any administrator can create new project directories, and chown them to a
project representative."
Thank you for you help!
Kind regards,
Timo
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2368#comment:11>
Keywords: |
Changes (by jef):
Comment:
/osgeo/download/oskari
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2368#comment:12>
Keywords: |
Comment:
Sorry for reopening an ancient ticket, but the background information is
in this one ![:slight_smile: :slight_smile:](/images/emoji/twitter/slight_smile.png?v=12)
There was some kind of change in the server infrastructure I think, and
for a while we were not able to connect and upload our releases. Now the
connection issue is solved but it seems the required project directory
/osgeo/download/oskari is missing from the server. Could you please check
what's going on, are we connecting the wrong server or is the directory
not mounted or something else?
Thank you!
Best Regards,
Timo Aarnio
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2368#comment:13>
Keywords: |
Comment (by jef):
Did you use upload.osgeo.org instead of download.osgeo.org (see
[[https://wiki.osgeo.org/wiki/Download_Server#Configuration|Download
Server]])?
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2368#comment:14>
Keywords: |
Comment (by zakarfin):
Replying to [comment:14 jef]:
Server]])?
Previously uploading through "download" has worked but I just updated our
script to use upload.osgeo.org instead and it worked. So this ticket can
be closed.
Thanks for the help!
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2368#comment:15>
Keywords: |
Changes (by jef):
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/2368#comment:16>
